2 Ports into 1 - Car Audio Classifieds!
Old 08-25-2012, 03:00 PM
SQLAudio's Avatar
0/11 sssssss42
Default 2 Ports into 1
I have been wondering this for a while. I have googled it and checked other sites but didn't find anything on it. When I build a ported box for two subs and want to put the port in-between the subs I typically do it like this...
I want do start doing my ports like this...
Is there anything I have to do to keep the same tuning frequency? I know I have to compensate for removing the center divider, but is that all? Let's say I am using 2" wide ports and I combine them into one 4" port. Thanks for the help guys.
Old 08-25-2012, 03:06 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Looks like youve got everything straight, should be the same minus the devider being gone and the space compensated.
Louder. Lower.
Team Tupperware
The Following User Says Thank You to Pioneer~Saturn For This Useful Post:
SQLAudio (09-06-2012)
Old 08-25-2012, 04:35 PM
SQLAudio's Avatar
0/11 sssssss42
Thanks, I want to do this and use flared ports (kerf cut).
Triangle ports....Corner ports? bigdhenderson Wiring, Electrical & Other Installation Equipment 11 04-09-2012 08:23 PM
Ports? lance.requa Enclosure Discussion & Design Construction Help 6 02-05-2012 02:42 PM
Slot ports vs aero ports? 87linkin General Car Audio Discussion & Questions 6 01-16-2010 03:09 PM
Simple question - ports up or ports forward? FatBoy2 Box Requests 20 09-21-2009 04:45 PM
Pvc Ports Vs Aero Ports - Help Bushj311 General Car Audio Discussion & Questions 24 01-07-2009 08:37 PM
