SA-12 fiberglass box - Car Audio Classifieds!
Old 09-02-2012, 04:45 PM
0/11 sssssss17
Default SA-12 fiberglass box
im building a fiberglass box for the side of the trunk in my g8, i made the back shell so far. what volume should make it? should i make it ported or sealed? someone help me with the specs im looking for sql. running at 2 ohm by an aq1200
Old 09-04-2012, 05:19 PM
0/11 sssssss17
anyone??
Old 09-04-2012, 05:22 PM
SacTownBully84's Avatar
0/11 sssss3682
Feedback Score: 51 reviews
1.5 - 2 cubes @ 35hz is recomendation from sundown
98 Taurus
: CRESCENDO : AT : SKAR : MEMPHIS :
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 09-04-2012, 05:24 PM
0/11 sssss3682
id say 2cubes if i was you.....lower power setups usually require more airspace to reach ideal output
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 09-04-2012, 08:09 PM
0/11 sssssss17
is mine considered lower power? im powering over rms?
Old 09-04-2012, 08:13 PM
Mr.G6's Avatar
0/11 sssss4614
just bc your amp specs are over rms..doesnt mean you will be seeing that power.. gotta account for impedance rise voltage drop etc..
staying around the 600 to 800w rms range stay in the 1.8 to 2cubic foot range.. use 12 to 16" of port per cube (i like 14" per best)
and ALWAYS ALWAYS ALWAYS do the big 3 upgrade
2000 Gmc Sonoma ext cab
Old 09-04-2012, 08:32 PM
0/11 sssssss17
if i plan on changing to 1 ohm in the future should i make it like 1.6? what do you mean 14"? calculator says Vb=1.6 tuned at 35hz port D=3 inch L=7.5 inch.
Old 09-05-2012, 12:05 AM
ltr450racer690's Avatar
0/11 sssss3414
1.5 cubes tuned to 30
AUDIOTECHIX DEALER
DLP CUSTOMS SALES REP
Old 09-05-2012, 12:07 AM
0/11 sssss3682
efficiency drops quite a bit @ 1ohm u wont gain alot more from that
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 09-05-2012, 12:09 AM
0/11 sssss3682
now if u had a AQ2200 @ 1ohm on it then id say 1.3-1.5 net but after rise and all with that aq1200 i bet u see 800 tops
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
The Following User Says Thank You to SacTownBully84 For This Useful Post:
ionakronik (01-16-2013)
fiberglass box for 2 sa-8 v2 cheebs (Sundown Audio) 26 08-09-2012 01:25 PM
Fiberglass 4 15's box Snwbrdr1 Bargain Bin 0 05-29-2011 02:38 AM
How to modify a fiberglass box gnesterenko Enclosure Discussion & Design Construction Help 8 05-05-2011 12:58 PM
Need a fiberglass box builder Ground Poundin Jeff Enclosure Discussion & Design Construction Help 8 04-22-2011 09:10 PM
Fiberglass sub box (3) 10"s Ricoshay Wiring, Electrical & Other Installation Equipment 0 08-18-2008 04:10 PM
