Cutting threaded rod with an angle grinder? - Car Audio Classifieds!
Old 09-03-2012, 11:58 AM
Default Cutting threaded rod with an angle grinder?
Any special disk I should get? I've heard that if you put a nut on the rod below where the cut is to be made you can then unthread the bolt over the cut to pull off any burrs. Anyone have experience? I don't have a sawzall here, the only other tools I have are a jigsaw and a horrible circular saw.
Baffle flex sucks BTW.
Old 09-03-2012, 11:59 AM
badmofo529's Avatar
0/11 sssss3329
Just a standard cutoff wheel will work
Sent from my Inspire 4G using Tapatalk 2
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 09-03-2012, 12:01 PM
you can get a cutoff wheel that will fit on your angle grinder, just make sure to leave the shield on and stay behind it. It hurts like a bastard if that cut off wheel explodes and comes back at you. Depending how thick rod you got you could just use a hacksaw.
Old 09-03-2012, 12:03 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
dont forget safety glasses....
god forbid if you get metal imbedded in your...
then they have to grind it out with a drillbit
Old 09-03-2012, 01:07 PM
Cool. I had to grind out all of the metal braces in one of my walls a while back. My arms had little scabs all over them for like a week, lol. I'll be safe, I promise. Thanks guys!
Old 09-03-2012, 01:08 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
justa cut off wheel, and yes, thread a nut below the cut, then thread it off afterwards.
Old 09-03-2012, 01:10 PM
Contributor
0/11 ssssss527
I cut everything with angle grinders, don't see why it shouldn't work I chop rusted bolts off with them all the time. A Dremel with a cut-off wheel or hack-saw with a metal blade may be more precise.
99Bonney's Avatar
0/11 sssss6246
Die grinders work well too and they're not priced too bad.
2006 Tahoe
Subs- 4 Crossfire xs v2 15s
Amps-Crossfire 8k
Batts- 6 xs 3100s, 2400
Alts- 3 Mechman SMD 340s
Old 09-04-2012, 10:24 PM
0/11 ssssss350
I've cut a lot of threaded rod with my current build. I would not use an angle grinder, too many sparks, flying metal, etc...
I used a hacksaw and a 2x4. Drill a hole in the 2x4 and then cut it with the hacksaw. Make sure you put a nut on both ends and it will de-burr the cut when you take the nut off. The 2x4 was held with a vise on my workbench.
Angle dual inputs utley (Tool Maker) 1 04-29-2012 04:57 PM
Threaded Rod? murderedtahoe General Car Audio Discussion & Questions 22 11-19-2011 12:50 AM
Brand New Snap On Die Grinder Jason19 Miscellaneous Stuff For Sale 0 09-13-2011 08:11 PM
Where to buy copper threaded rod Bubba906 General Car Audio Discussion & Questions 4 06-20-2011 07:41 PM
Reconing a XXX! no side grinder? boboridesbmx General Car Audio Discussion & Questions 9 07-10-2010 03:14 PM
