Need help with box design. - Car Audio Classifieds!
Old 09-06-2012, 03:43 PM
0/11 sssssss23
Default Need help with box design.
Hello all. atrying to figure out the perfect box for a sub I purchased off of here. Draining my brain trying to calculate all these numbers. As I can't seem to figure out winsld or any of the like. Guess I'm just to old school. Was wondering if anyone would be kind enough to run the numbers threw any program for me. Looking for a slot port sub up port back design for a 98 jeep cherokee. Sub is a soundstream T4 10" dual 1ohm coils. Here's the numbers. If any are missing that are needed let me know and I'll see if I can find them.
FREQ. RESPONSE (Hz) : 28 - 1.8k
Fs (Hz) : 40
Qes: 0.397
Qms: 1.975
Qts: 0.330
Vas (Ft3) : 0.35/9.79 liters
Xmax (INCHES) 0.63
SPL (dB) : 87
HOLE SIZE (INCHES) : 9.5
WOOFER DEPTH (INCHES) : 5.75
RECOMMENDED ENCLOSURE (Ft3) : Ported 1.7
Sub will be wired @ 2 ohms running 600-800 watt rms. Thanks in advance for any input.
Old 09-06-2012, 04:34 PM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
just use Torres box calc from SMD
if not i can do a design for you for 5bucks
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
Old 09-08-2012, 08:34 PM
0/11 ssssss772
Default box
hey how much your charge me for design cut sheet for pair sundown 12s
What box design would be the best.. dave_rx (Sundown Audio) 12 08-17-2012 05:35 PM
box design michael707 General Car Audio Discussion & Questions 1 09-29-2009 04:18 AM
