Any tips on building wall - Car Audio Classifieds!
Old 09-07-2012, 03:30 AM
916slapin's Avatar
0/11 ssssss825
Default Any tips on building wall
I am gonna be walling a 1992 Saturn sl2 I picked up. I have never done a wall but always wanted one, also with tuning would say 25hz be to low I just want it to demolish the lows. I am thinking about doing 4 15s if I have the room. I'll upload pics of the car tomorrow
Old 09-07-2012, 05:32 AM
0/11 sssss1090
for my first wall which is my current setup i didnt make the walls thick enought.
needs to be WAY THICKER. wanting to take my baffle off and add .75 MDF board to every wall. THEN more bracing. right now its only 1'' thick.
and try to seal it off behind the A pillar. as in air tight if you can.
Old 09-07-2012, 05:33 AM
0/11 sssss1090
also after a replacement my new baffle is now 3'' thick.
Old 09-07-2012, 06:50 AM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
first tip. Bracing is never "just enough"
fiberglass is your friend.
great stuff is your hoe
thats about it lol
Old 09-07-2012, 07:27 AM
thegreatestpenn's Avatar
lazy genius
0/11 sssss2592
Feedback Score: 25 reviews
don't forget the "dancefloor". take 2x4s to make a "shell" around the area u plan to use for the wall (typically from rear deck to the b-pillar or just behind the farthest point your front seats go back). Fill the area between the shell and actual doorpanels and stuff with foam/great stuff. Then get to building your enclosure. save the trunk for amps and batts
and good luck
MECA spl and sql judge
termleezy fo-sheezy
Old 09-07-2012, 09:31 AM
916slapin's Avatar
0/11 ssssss825
Do you glue everything inside the car? For the sides could I just do 1 layer of mdf and glue/screw 2x4s to cover the whole the side walls to add strength.
Old 09-07-2012, 09:33 AM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
unless you have a jeep or something and you can slide it in and have a forklift to do so you build a wall in the car.
Old 09-07-2012, 09:35 AM
916slapin's Avatar
0/11 ssssss825
Yea thats whati was thinking I'm gonna have to do how did you glue things in there lol
Old 09-07-2012, 10:05 AM
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
build it out on paper first... literally.... step by step all the way to the point of making beauty panels and wiring up the last thing... you will find that you need to change steps and make room here and there.
you probably wont like me
Old 09-07-2012, 10:23 AM
Darcaudio17's Avatar
0/11 ssssss325
POCKET HOLE JIG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
makes building in vehicle 102842197x easier
Amazon.com: General Tool 849 E Z-Pocket Hole Jig Kit: Home Improvement
SUBS: 6 ia dp 12s
SUB AMP: 1 IA 40.1
HIGHS: 8 apmb 6s and 4 tw44 tweets
HIGHS AMP: nendo 1kc4
BATTS: up in the air
ALT: 320a Tenney alt
The Following User Says Thank You to Darcaudio17 For This Useful Post:
SINTORMAN (09-07-2012)
Building a wall xnewbx Enclosure Discussion & Design Construction Help 2 08-23-2012 07:28 PM
Rules/guidelines/tips of building 4th order bandpass AFlem Enclosure Discussion & Design Construction Help 3 01-04-2012 02:12 PM
Box Building Help/Tips Bologna General Car Audio Discussion & Questions 15 12-02-2011 06:59 PM
Building box in trunk: Tips Drillrig52 Enclosure Discussion & Design Construction Help 9 11-20-2011 01:22 AM
anybody got any tips for building a box in the trunk Craig28 Enclosure Discussion & Design Construction Help 11 05-06-2011 12:27 AM
