Is this enough port area? - Car Audio Classifieds!
Old 09-07-2012, 02:35 AM
serjr711's Avatar
0/11 sssss2699
Feedback Score: 65 reviews
Default Is this enough port area?
Here is the proposed box for 2 15" smd's in my ext cab, ports up subs forward. Will be using sonotubes coated with resin.
Old 09-07-2012, 05:03 AM
Re_Silverado's Avatar
0/11 ssssss590
How much power? That ss 10k? When using more power you can get away with less port area, especially if using aeros.
Old 09-07-2012, 11:05 AM
LOL what? You're doing to move more air with more power, port area should increase.
For huge round ports like that 12in^2/ft^3 should be fine. Some people will tell you to go larger, but I don't think going any bigger will make a difference.
Old 09-07-2012, 01:18 PM
0/11 ssssss590
That is true, but that is not what I see happen usually when it comes to aeros most of the time.
too much port area? contourbass General Car Audio Discussion & Questions 3 05-09-2012 03:23 PM
help with port box a per and port area per ft lilsoccersully Enclosure Discussion & Design Construction Help 0 05-02-2012 09:04 PM
Port area for 2 15 SPL Addict General Car Audio Discussion & Questions 0 03-14-2012 11:31 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 09:52 PM
