WinISD help me please - Car Audio Classifieds!
Old 09-09-2012, 10:28 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Default WinISD help me please
I am designing a box for my wall with 4 OA 18's on winISD.
I am inputting driver specs, and don't know what to put for Z___(ohm) and Pe___(W).
help me fill in the blank please.
Old 09-10-2012, 12:15 AM
Pe is power handling (put in what you "think" they can handle, not 600 watts, lol)
Z (nom, or nominal) is nominal impedance. If you're running the coils in series that would be 8, in parallel that would be 2.
Old 09-10-2012, 12:42 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
You really don't need to worry about Z. Winisd is fairly basic, you really just need Vas, Qts, Qes (port velocity, but be careful), Fs, and Pe. Pe is thermal power handling. Just put whatever your RMS rating is on your woofer.
Old 09-10-2012, 11:42 AM
btsteinb's Avatar
0/11 sssss3573
So if i only input those stated above, i would get the same results as if i input all of the stuff?
Old 09-10-2012, 01:14 PM
For everything you'd be interested in, yes. I don't think WinISD factors in thermal losses or anything like that.
Old 09-10-2012, 02:28 PM
btsteinb's Avatar
0/11 sssss3573
Thanks for the help guys. Ill start playing with it tonight.
Old 09-10-2012, 06:59 PM
ddbump's Avatar
Loyal Member
0/11 sssss2385
Feedback Score: 17 reviews
Smarty pants
1996 dodge ram 1500
-12 Tantric HD 15s
-4 AQ 3500.1s
_TEAM D.O.A_
_TEAM DTF_
Old 09-10-2012, 10:10 PM
btsteinb's Avatar
0/11 sssss3573
Originally Posted by ddbump View Post
Smarty pants
someone has to know how to fix all ur shit
Old 09-24-2012, 06:45 PM
gotta love clean builds
0/11 sssssss85
z is the impedance of the woofers so ex. d2 woofer wired in series will have a z of 4. and the pe___(w) is the peak watts of the woofer i believe i have noticed that those two variables do not effect the performance of the woofers in winisd. i do not worry about them and i leave them blank alot
WinISD help Scapelli21 Enclosure Discussion & Design Construction Help 0 05-29-2011 05:31 AM
winISD help. davidrforbus General Car Audio Discussion & Questions 1 05-26-2011 11:48 AM
winisd 20Hz_And_Below General Car Audio Discussion & Questions 12 02-01-2011 09:35 PM
winISD fyerbyrd22 General Car Audio Discussion & Questions 8 03-04-2010 09:19 PM
winISD help coefamily Enclosure Discussion & Design Construction Help 6 01-20-2010 04:54 PM
