Port Questions - Car Audio Classifieds!
Old 09-14-2012, 08:41 AM
0/11 sssssss17
Default Port Questions
i just built a box for my 2 type r's and was wondering if when using 2 or more ports you make them all the same size for the tuning you want. or do you get the total length and split it by how many ports you want?
Thanks.
Old 09-14-2012, 12:02 PM
The length stays the same across all of the ports. THe only thing you can slipt up is the port area, so for example:
(1) 10" x 6" port that is 20" long
is the same tuning as
(2) 5" x 6" ports that are both 20" long
When using multiple ports remember not to go too small or you will get port noise.
mx_rider_94 (09-14-2012)
My first wall.. center port questions Racerkid15 General Car Audio Discussion & Questions 13 11-03-2011 08:21 PM
Port questions. davidrforbus General Car Audio Discussion & Questions 2 10-12-2011 04:58 AM
Port area questions ( 2 12w7's) glowbox Enclosure Discussion & Design Construction Help 7 01-22-2011 06:48 PM
Questions about port design maddog2099 General Car Audio Discussion & Questions 1 08-30-2010 07:42 PM
port questions. 1loudmonte General Car Audio Discussion & Questions 15 12-28-2009 08:35 PM
