Sa-15 box help - Car Audio Classifieds!
Old 09-14-2012, 11:51 AM
0/11 ssssss340
Default Sa-15 box help
I have two sa-15's I will be putting on a 3k. My main goal for this box is to move air. I want a ground pounder that will move some air. I don't care about numbers, but I don't want a terrible band width. It will be a back seat build, so dimensions are roughly 40x22x20. I can go a little higher if needed, maybe a little wider or deeper as well.
Q
I was planning on running a 10' aero (78 sq in. Port, 11/cube, I'd probably just use a concrete tube or PVC pipe without a flare) tuned to 32. Subs forward, Port up?
I was thinking 7 cubes, or is that a little high for the power I'm running? (saz 3k at 1 ohm)
Car will be a 97 prelude sh.
Or I could do a slot port, 84 sq in. Of port(12/cube) and do subs/port forward.
Old 09-14-2012, 11:57 AM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
3k on a single sub and 7 cubes is wayyyy too much for a single 15?
Old 09-14-2012, 12:14 PM
0/11 ssssss340
A pair of em. Sorry put to instead of two
Old 09-15-2012, 01:09 PM
0/11 ssssss340
Any help?
Sent from my SGH-T989 using Tapatalk 2
Old 09-15-2012, 01:13 PM
Austin175's Avatar
0/11 sssss4224
i have my pair in a 7cf box with two 6" areos tuned to 35hrtz an they pretty loud an low( can play down to 25hrtz ftw). but mine are subs up port back.
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Good, 3+ cf ported box for a 12 inch sub or a box builder (central WI) Wingman0121 Wanting to Buy (WTB) 0 06-16-2012 08:58 PM
Dave the Box Guy Sub box for 2 15's 7'^3 @ 42hz for SUV 80$ OBO New England area hispls Wiring, Electrical & Other Installation Equipment 8 05-21-2011 02:43 AM
Box design request for da box king ( 2-12" R's) da box king Box Requests 3 08-16-2010 04:23 PM
18" trunk box dual corner loaded square port box Jacobbz206 Enclosure Discussion & Design Construction Help 0 06-20-2010 06:53 AM
