EXPERIMENT: Compare response curves... - Car Audio Classifieds!
Old 09-20-2012, 11:55 AM
Supergumby5000's Avatar
0/11 ssssss642
Default EXPERIMENT: Compare response curves...
Little bit of a visual experiment here: Give me your opinions on these response curve models
-The red curve depicts how i THINK the boxes will perform
-The orange/yellow lines are fluctuations due to cabin-based affects
-The teal line is just a raw box model with zero environmental considerations
If both could be built, which would you use and why? Remember, this is strictly based on the response curves only!
All you box gurus and wanna-be experts with e-boners, please play along without turning the thread into waffles.
Old 09-20-2012, 12:12 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
What is "turning into waffles?"
Is this a 6th order? How did you come up with the red line? How did you predict the orange and yellow?
I'll take teal, please.
Old 09-20-2012, 12:16 PM
0/11 ssssss642
Sorry for the confusion. Not which direct curve, which box design.
One is ported, one is a parallel 6th.
The point of the thread isnt to analyze how the curves were depicted though. I'm curious to see how people will pick their boxes.
If you compare the two, looking at the raw box model (teal) line, one box has lower response in the 30-40hz range and one has a higher response. However, with the effects of the cabin, they model rather similarily.
EDIT: "waffles" as in people who know what their talking about (or have no idea) making this more complicated than it needs to be, as this is just an experiment based on peoples choices visually.
Old 09-20-2012, 12:18 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
#2. You can maniulate the slight bump(if there is one) and achieve a flatter response over a larger BW.
The Following User Says Thank You to audioarsonal For This Useful Post:
Supergumby5000 (09-20-2012)
Old 09-20-2012, 12:29 PM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
Whats the design to be used for?
Old 09-20-2012, 01:03 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
for clarity, i believe i would opt for the parallel 6th order,.. less processing needed to flatten 'er out further to the ear and is already built with a somewhat ideal (to me) h/p rolloff to work with. although, they are inherent with their own flaws
im working on one right now with a 40-80hz bw for a pair of hdc3's,.. if bbp6 is accurate enough with the stuffing properties, it seems that heavy fill will attenuate the peaks to an even more manageable plot.
<---still learning
who wants a nudel ride?
Old 09-23-2012, 11:06 PM
0/11 ssssss543
Is your cabin gain calculated or hypothetical? If using the correct driver and built to perfection the 6th will do better theoretically, but real world I've not had great luck with 6ths even when they model much better. If using a 6th I would do series tuned as they are a tad more forgiving. Now without any outside factors if you want me to just k.i.s.s. then the 6th looks better on paper.
Bought from - Hazardous0388 (4 db Drive 2000.1s), Psychoacoustics (4 Powerbass XA 3000'ds), and blackedoutavy (PPI A200)
Sold to - D-Rew (Knu 1/0), d77543020 (Knu 1/0), F1McLarenAGR (Audioque 4x90), and SacTownBully84 (Knu 1/0)
Traded with - SacTownBully84 (my xa3kd for his xa1.5kd + cash)
No response? AudioXtremes (Fix My Speaker) 2 05-01-2012 09:01 PM
No response romeo74 (PSI Car Audio) 3 09-07-2011 05:12 PM
How will this compare? wcjake15 General Car Audio Discussion & Questions 4 03-13-2011 11:02 PM
Delay in response [email protected] General Car Audio Discussion & Questions 0 01-07-2011 08:44 AM
how do these compare to each other GODHATESCIVICS General Car Audio Discussion & Questions 9 05-25-2010 07:48 PM
