ported and getting LOW - Car Audio Classifieds!
Old 09-29-2012, 04:16 PM
massivespl's Avatar
0/11 sssss8409
Default ported and getting LOW
my question is i had 289inches of port tuned to 32hz and i peaked at 33hz in my tahoe, then i change the port to 204 sq inch tuned to 31hz and it seems that it peaks alittle higher then then the first port. i havent gotten it on the meter yet since i have the new port but the new port is tuned 1hz lower but plays the highs better to my ear.
so if i want lows should i make the port have more sq inches and tune lower?
im really trying to learn about how to choose the right port specs.
the equipment im using is in my sig.
gunna be building a new box sometime soon and trying to do it right this time. goal is 52's on music which should be able to do with 4 18's on 7.5k
thanks to anyone that helps.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-29-2012, 04:20 PM
99Bonney's Avatar
0/11 sssss6246
A couple people have tested the theory that you need less port area for lower tuning and more port area for higher tuning. Might've been cj18 or one of the dc guys that had posted that.
Old 09-29-2012, 04:24 PM
massivespl's Avatar
0/11 sssss8409
got a link to this? i tried searching for something but came up dry
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-30-2012, 02:18 PM
massivespl's Avatar
0/11 sssss8409
anyone have any info?
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-30-2012, 02:28 PM
99Bonney's Avatar
0/11 sssss6246
I believe it was on SMD. I tried searching for a bit too. Honestly, just "steal" a design that's proven lol. You know what they are.
Old 09-30-2012, 02:31 PM
massivespl's Avatar
0/11 sssss8409
im trying to find a design that will work for me and my space. i really dont think just makin my box 3 inches shorter is going to gain me 4db but i could be wrong because next we gotta cut the box down 3 inches before we make a new one.
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-30-2012, 02:37 PM
99Bonney's Avatar
0/11 sssss6246
I mean there's only so many ways you can build the same specs on a square box and have same port area. With all else equal, messing with your vehicle.
Old 09-30-2012, 02:52 PM
99Bonney's Avatar
0/11 sssss6246
Here's the quote that I read from CJ about tuning and port area.
"I cant explain why it is and dont really care to know the reasoning behind it, but in the builds I have done, the lower that you want to tune, the less port area you need. If you want to tune to 30hz or lower. 10-12in2 of port. 30-35hz 12-14in2, 35hz and up 14-16in2 of port.
In all honesty, so much of it just depends on the vehicle and the box. I can build 2 boxes that are built to the exact same specs and 1 may sound and peak completely different than the other.
This game we call car audio is all about testing. It can get really irritating at times, but the result in the end is worth the pain!"
Link
Port Area VS Low Tuning - Subwoofers / Enclosures - SMD Forum
The Following User Says Thank You to 99Bonney For This Useful Post:
massivespl (09-30-2012)
Low tuned ported wall question Re_Silverado General Car Audio Discussion & Questions 8 08-29-2012 08:06 AM
how low is too low for a sundown amp? scfaust General Car Audio Discussion & Questions 11 07-25-2011 04:57 PM
BNIB Treo rsx 1900. for the LOW LOW snoopysnooper Mono Amplifiers 8 05-04-2010 03:53 PM
[TRADED] 8" resonant engineering re8 on the low low snoopysnooper 8" Subwoofers 17 12-14-2009 01:31 PM
Low coolant warning light - Its not low tho..??? westman995 General Automotive Chat 9 11-24-2009 08:45 PM
