Port area - Car Audio Classifieds!
Old 10-02-2012, 10:04 AM
witherman's Avatar
Will work for subs
0/11 sssss2280
Default Port area
Quick question about port area...
Setup:
2 AQ hdc4 15s
Sundown 4500 @1 daily, probably going to a quarter for burps
Box:
7.0 cubes after all displacements.
Question is, I currently have 6" aeros to use but don't have a lot of experience with them. According to psp's calculator I can get to tuning at an acceptable length with 2 of them. This will get me to 32hz but my question is more the fact of is just over 8^2 of port per cube acceptable?
Thanks in advance!
Old 10-02-2012, 10:15 AM
0/11 ssssss697
I found this in a different thread, but the sub they were talking about was a HDC4 12.
"As for the port area, aeros are great, but not if you cant get enough port area. AQ LOVES alot of port area. AQ suggests 16-18 sq inches of port per cube for loud daily applications. I personally stretch that to 18-20 sq inches per cube for loud daily, and 20-22 sq inches per cube for burps. A single 6 inch aero works out to be 6.25 sq inches per cube, and an 8 inch equals 12.5 sq inch per cube. Ive tried small port setups with AQ. Output will suck, and the sub (esp on high power), will not like you at all. "
Old 10-02-2012, 11:58 AM
witherman's Avatar
Will work for subs
0/11 sssss2280
Thanks for the info. Back to the drawing board lol
help with port box a per and port area per ft lilsoccersully Enclosure Discussion & Design Construction Help 0 05-02-2012 09:04 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 09:52 PM
Do I have enough port area for my sub reeftopia General Car Audio Discussion & Questions 4 09-27-2011 03:16 PM
port area lantz Enclosure Discussion & Design Construction Help 10 12-27-2009 02:03 AM
