Torres box help 12" nsv1 - Car Audio Classifieds!
Old 10-02-2012, 11:48 PM
0/11 sssssss67
Default Torres box help 12" nsv1
So i'm building a box for a 12'' nightshade v1. I plugged in what i wanted into torres and got roughly 2 cubes at 33.5hz. I want to know if i have to factor in the 3/4 mdf in the cut sheet? I attatched the screen shot from torres and im really just trying to figure out the cuts.
This is what i've come up with for my cut sheet:
Top: 26x16
Bottom: 26x16
Left: 13.5x15.25
Right: 13.5x14.5
Front: 22.5x13.5
Back: 26x13.5
Port 1: 13.5x14
Port 2: 13.5x12
Baffle: 21.75x13.5
Thats with factoring in the 3/4 mdf... Hope this isnt too confusing, i just dont want to mess up. First time using torres. Any help would be appreciated. I'm sure im making this way harder than it needs to be.
Old 10-03-2012, 01:48 AM
Enlarge that image a bit.
Gabriel ruiz (10-03-2012)
Old 10-03-2012, 09:01 AM
0/11 sssss3842
It shoulda have a spot to check .75" wood thickness. should be set to that at default.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 10-03-2012, 09:06 AM
0/11 sssssss67
I can't figure out the photo thing but i will post all of the specs on the sheet:
Box outer dimensions: 15" Height, 26" width, 16" deep
Port dimensions: 13.5 Height, 2" width, 26" long
Displacements: 0.18 woofer disp, one extra baffle, 3 common port walls.
Cut sheet:
Top: 26x18
Bottom: 26x18
Sides: 13.5x14.5
Front/back: 26x13.5
Port top/bottom: Too complex to display
Port sides: Too complex to display
Box stats:
Gross: 2.75ft^3
Port volume: 0.42ft^3
Physical port: 22.50"
Port bends: YES
Baffle disp: 0.14ft^3
Port area: 27in^2
Port area per foot: 12.77in^2
Port ratio: 1:6.75
Net volume: 2.04ft^3
Tuning freq: 33.75 Hz
Sorry for the huge post, only way i knew how to do it.
Old 10-03-2012, 09:10 AM
0/11 sssssss67
Yeah I have the .75" wood thickness selected, but I didnt know if it took it into considertation. I've used re box builder in the past so transferring to this seems different... Much better, but different.
Old 10-03-2012, 09:18 AM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
I never go with Torres' cut sheet. After plugging in numbers, I draw it out in sketchup and then take my measurements from that.
Old 10-03-2012, 10:11 AM
0/11 sssssss67
Is there a place to download sketch up? I'm trying to get it built today because I am off.
Old 10-03-2012, 10:39 AM
0/11 sssss3842
just google "google sketchup"
and where did you download Torres from? mine doesnt look like that.
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 10-03-2012, 11:04 AM
0/11 sssssss67
Ok thanks. And I just changed the background color because I could see it better that way. I think I'll jut go with my gut and go ahead and cut what I have. I think it should work.
Old 10-03-2012, 12:01 PM
0/11 ssssss106
I just downloaded sketchup earlier this week and I'm getting the hang of it. There is a really good tutorial video on youtube done by caraudiofabrication for google sketchup. He shows step by step how to draw a box. Good luck.
The Following User Says Thank You to Butterworth For This Useful Post:
JPTheRE12 (10-03-2012)
2 nsv1 15 box recomendations natt3000 Enclosure Discussion & Design Construction Help 7 09-26-2012 12:09 AM
who uses torres box calculator? snyderd758 Enclosure Discussion & Design Construction Help 6 05-03-2012 10:06 PM
torres box calculator and tablet kansas39503 Off Topic Chat 0 08-24-2011 08:28 PM
Torres box calculator HELP!!! loudernu Enclosure Discussion & Design Construction Help 1 05-28-2011 05:59 AM
torres box tuning problem Russellabt General Car Audio Discussion & Questions 2 03-26-2011 02:18 PM
