look ok? - Car Audio Classifieds!
Old 10-03-2012, 02:11 PM
0/11 sssss3842
Default look ok?
Single Skar vvx12. mainly just concerned about port. took me while to get it worked out.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 10-03-2012, 02:21 PM
0/11 ssssss577
bring your net cubes up to about 2 - 2.25 then try the port width at 3"
this is very close to the box i use for my sa-12
Old 10-03-2012, 02:26 PM
0/11 sssss3842
will try that. I was thinking net around 2 but SKAR recommends 1.5-2. So was aiming towards little less than 2. plus dimensions given to me to work with for the customer is VERY tight.
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 10-03-2012, 02:39 PM
0/11 ssssss577
if they are running say 1k you will want a high net like 2 or just over to keep effiency up
Old 10-03-2012, 02:55 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
isnt it the other way around, the more power, the smaller the enclosure?
Old 10-03-2012, 03:04 PM
0/11 ssssss577
yes you are right, i should have said a 1k amp most daily setups with a 1k amp will see less then the rated power of that sub. and i have found in past experiences(with this and similar subs) they have no issues with a 1000 +- clamped watts witch is the average power of say a 2k or 1500w amp after rise ect.
