What kind of enclosure is this? - Car Audio Classifieds!
Old 10-05-2012, 05:27 PM
0/11 sssssss28
Default What kind of enclosure is this?
Ok, I'll do my best to describe this as it was back in the day (early 90's). Buddy had a pair of 8's that sounded absolutely incredible!!! People used to always think he had 12's or bigger - LOL! System was a high end Alpine head unit, Infiniti components, Orion Amps, etc.
Best way to describe the box (one for each speaker) was a big rectangle. Maybe around 42" long. Depth and Height was probably around 24". Recognize I'm pulling these numbers straight out of my a$$ so I could be way off on dimensions as 20 years can cloud the memory a tad. You couldn't see the speaker. It was basically mounted in the center of the box. Each end of the box had a slot that ran from side to side and was probably 3/4-1" thick.
I hope I described that correctly. If not let me know what isn't clear and I'll try to explain it better.
Bottom line, you had to have space, but or what they were those speakers POUNDED!!!
Old 10-05-2012, 05:29 PM
CHEMMINS's Avatar
0/11 ssssss826
Sounds like 2 mini 4th orders back to back in a single box.
2007 Dodge Megacab Diesel 5.9 - Alpine W200 installed......RHS is partially installed. AT Deadener on inner doors. Interior tore apart....only seats in er right now.
BUYING SILVER TRF MOTORS and 15" XXX BASKETS IN GOOD SHAPE!!!!
Old 10-05-2012, 05:43 PM
0/11 ssssss376
My friend used to have 2 rf 8's in a box like that way back in the day.i thought it was called a isobaric enclosure
Old 10-05-2012, 06:22 PM
Draw a picture in paint and upload it as an attachment here. COuld you see the speaker cones if you looked down the port, or were they completely inside the two sides?
Old 10-05-2012, 06:23 PM
0/11 sssssss28
2 separate boxes same size/design. Took up most of his trunk---lol
0/11 sssssss28
I'll see what I can come up with. You couldn't see the speakers.
Old 10-05-2012, 06:48 PM
goatskindreams's Avatar
Do you even demo?
0/11 sssss1797
1/4 wave t line possibly
Old 10-05-2012, 06:51 PM
kremer90's Avatar
0/11 ssssss284
did each seperate box have 2 slots (ports)? could have been parellel tuned 6th orders? those would be rather large too
Learning to get "loud"
Old 10-10-2012, 07:52 PM
0/11 sssssss28
Ok, did some surfing and finally found the design. They were indeed a 6th order dual reflex bandpass design. Those 8's sounded amazing!!! Impressive to say the least.
Old 10-10-2012, 07:54 PM
I could out do that with 1 modern 8" now
stuff has come a long way since the early 90's.
What kind of enclosure is this? Matt3824 Enclosure Discussion & Design Construction Help 15 10-19-2011 10:20 AM
what kind? FOGEL A.KA.MCLOVIN Enclosure Discussion & Design Construction Help 3 10-06-2010 09:31 PM
Another Kind Of Evil only126db Off Topic Chat 1 08-13-2010 09:02 PM
WTB: ported 12" enclosure of some kind snoopysnooper Wanting to Buy (WTB) 10 10-06-2009 09:01 PM
