using areo ports? - Car Audio Classifieds!
Old 10-09-2012, 06:36 PM
0/11 sssssss28
Default using areo ports?
So I've been researching areo ports and wanted to build a box at some point using them, but the main question I have is how do you go about having the ports sticking out? Most places just say have the whole port inside the box, and I want them sticking out. Would this be the same as just having a slotted port that sticks out?
Old 10-09-2012, 06:43 PM
Infinitelybaffled's Avatar
0/11 ssssss816
Yes. It will be louder that way, too.
Inappropriate sig image.
Old 10-09-2012, 06:45 PM
99Bonney's Avatar
0/11 sssss6246
Why do you want them sticking out? Do you want the whole thing sticking out or part of it? I usually just keep the whole port inside for ease of mounting and it's easier to fit. If you want part of it sticking out then you'll have to make rings to go around the port until your desired length. If you want it 100% external then just flip the mounting flare and screw it in the same way you would if its internal.
Hope that helps.
Old 10-09-2012, 06:48 PM
99Bonney's Avatar
0/11 sssss6246
I think that would depend on the application. Mainly just because your enlarging the internal space.
Old 10-09-2012, 06:50 PM
Skip01's Avatar
Ladies MAN
0/11 sssss5551
THAT
Youtube VIDz :
Old 10-09-2012, 06:54 PM
psychoacoustics's Avatar
Veteran Member
0/11 sssss3830
Feedback Score: 50 reviews
Internal ports displace cubic feet
External don't
Simple as that
It will just require changing your box measurements to not account for port displacement
Sent from my DROID SPYDER using Tapatalk 2
The Following User Says Thank You to psychoacoustics For This Useful Post:
dakota660 (11-22-2012)
Old 10-09-2012, 07:07 PM
0/11 sssssss28
Well I'm not worries as far as the difficulty of installing a areoport partly inside, just didn't know what difference it made aside from displacment, or if tuning was different, And whether or not there were major cons to having it protruding out, may it be partly or entirly
Old 10-09-2012, 07:11 PM
0/11 sssssss28
Originally Posted by Skip01 View Post
THAT
To be honest, I like the look of external aero ports.
And I'm sortve limited on spaace for the enclosure.
Old 10-09-2012, 07:46 PM
0/11 ssssssss5
the thing with aero ports is as previously said, you can use them to decrease internal air space with the sacrifice of having it external, which is proven to work in spl builds, ie: crx's which have the external. but with the aero ports on the internal, you need a bigger box to get the proper airspace. the aero ports on internal, i'm not to sure, but seem to be more for daily? but i think they look better to the eye on the inside then the outside, but i go by my ear more than my eyes.
Old 10-09-2012, 07:51 PM
99Bonney's Avatar
0/11 sssss6246
If your limited on space then good luck fitting them external. They take up very little space, just keep them internal.
[SOLD] 4" Areo Ports (3 BNIB) AQ4Lyfe Wiring, Electrical & Other Installation Equipment 8 12-23-2010 11:44 AM
WTB big ass areo ports audiobahnfan Wanting to Buy (WTB) 3 09-11-2010 06:19 PM
Looking for some areo ports Spencers Wanting to Buy (WTB) 1 03-28-2010 07:26 PM
WTB: 5" Areo ports FOGEL A.KA.MCLOVIN Wanting to Buy (WTB) 5 01-10-2010 09:13 PM
4 or 6 inch flaired areo ports telly44444 Wanting to Buy (WTB) 3 11-11-2009 08:27 PM
