what is the best material to build an economy enclosure? - Car Audio Classifieds!
Old 10-12-2012, 09:58 PM
caloriu's Avatar
0/11 sssss2863
Feedback Score: 107 reviews
Default what is the best material to build an economy enclosure?
i am looking to build a box for 2 IA DP'S 18" and was wondering if 3/4 plywood can be used? im trying to cut weight down otherwise id use mdf and if funds were available id use birch. any ideas ?
thanks
Old 10-12-2012, 10:01 PM
0/11 ssss31257
yes, Plywood can be used.
$26 per 4'x8' sheet should get you BC pine plywood.
Old 10-12-2012, 10:04 PM
caloriu's Avatar
0/11 sssss2863
very nice sonic, as usual you know your stuff. i got to look around alot of my hardware stores dont carry full sheets or even 3/4 . btw what does bc stand for ?i just want to make sure i get the right stuff.
Old 10-12-2012, 10:09 PM
0/11 ssss31257
BC means the top is B grade and is sanded kinda smooth. the bottom is C grade and is not very smooth.
Old 10-12-2012, 10:33 PM
newarkbeast973's Avatar
1/11 sssss7810
I say instead of a hardware store. Try to find a wood place (can't thi k of the actual name ATM). They will have better quality stuff imo
New build coming soon!!
Old 10-12-2012, 10:38 PM
mega fatty
0/11 sssss6008
lumber yard....
and you can get decent birch ply for $35 a sheet, so why not spend the extra $10. it may even save you weight.
just look at different places
07 mazdaspeed3
rd d9 @ .5ohm
The Following User Says Thank You to tymoto21 For This Useful Post:
bigdhenderson (10-14-2012)
Old 10-12-2012, 10:39 PM
badmofo529's Avatar
0/11 sssss3329
Originally Posted by tymoto21 View Post
lumber yard....
the $35 birch is just regular ply, with birch veneer on the outside
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
The Following User Says Thank You to badmofo529 For This Useful Post:
iamsonic (10-13-2012)
Old 10-12-2012, 10:40 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
Mdf is used for a good reason. second best is brich. but you cant copy the sound of a good mdf enclosure IMO. burch always has a weird sound to me. could just be plecebo
Old 10-12-2012, 10:46 PM
HiloDB1's Avatar
0/11 sssss3158
Why cheap out on the enclosure? Its not like your running sony xplods or something.
Old 10-12-2012, 11:00 PM
mega fatty
0/11 sssss6008
you can find the good stuff for cheap, even menards had it on sale a while ago, down from like $52 a sheet. i have a lumber yard local and they do seem to be a bit cheaper then most lowes or home depots
07 mazdaspeed3
rd d9 @ .5ohm
2005 Lexus GS Economy Build Scott P Build Logs 13 12-09-2010 07:51 AM
Economy 12" subs ghostmechanic 12" Subwoofers 0 11-03-2009 02:54 AM
My views on our economy bumpin buick Off Topic Chat 7 11-10-2008 10:55 AM
