Have a question I've never seen asked before! - Car Audio Classifieds!
Old 10-15-2012, 12:31 PM
0/11 ssssss461
Default Have a question I've never seen asked before!
I just threw together a 4th order box for my Z v.3 12. I didn't want to glue/seal any pieces so I could adjust tuning or sealed/ported ratio. The box sounds really good as is, but I would like the peak to be just a tad higher. The tricky part is that the box has some air leaks in it as is, because I didn't glue or silicone anything. So my question is: how do air leaks affect the tuning of a box? I just don't want to seal everything up and then find out the box sounds completely different than when it was leaky. My guess is that sealing a leaky box will actually drop tuning a little. Is that correct or am I way off?
Old 10-15-2012, 12:38 PM
HHR_Ed's Avatar
0/11 sssss1871
It may, but depending on where the leaks are, it may cancel out a bit of frequencies and throw everything off.
You can use a rubber glove, get some liquid nail and coat the seams on the outside and still be able to pull it off if you need to.
Ed Lester.
YouTube
Old 10-15-2012, 03:55 PM
ludeman's Avatar
0/11 ssssss468
Try weather strips, i use them on box I had with different baffles.
Ray-TDH
Ray
been asked before but ellocojorge (Tool Maker) 3 04-10-2012 08:52 PM
For those of you that asked... RollerDJ Off Topic Chat 86 02-12-2010 07:55 PM
Might have been asked before? KickerCobalt Off Topic Chat 5 10-06-2009 11:14 AM
Seller asked this be recycled dblover Recycle Bin 1 08-23-2008 10:16 PM
