help finishing box design - Car Audio Classifieds!
Old 10-16-2012, 12:49 PM
Brand New Members
0/11 ssssssss4
Question help finishing box design
ok i have a design im working on its actually a modified version of another design that i have but im trying to adjust it to where it will fit in my vehicle better since the original box was not built for it. its for 4 sa 12's and im using a 4500 saz amp . the car is a 2005 subaru legacy sedan. the old box had the subs firing up and 3 6 inch aero ports from parts express firing into the cab of the car. the dimensions are 35 1/2 wide by 13 1/2 tall by 28 deep.
ok now that thats out of the way that is the old setup the new one will still be using the same subs and amp just my dimensions and ports will change my maximum external dimensions are 32 wide by 12.25 tall by 36 or 37 deep. i still want the ports firing forward into the cab and im using 3/4 birch so question is what size ports should i use since i cant fit the 3 6" aero's in it properly and also how long should i make them. id like it tuned to about 42hrz . any advice or help is greatly appreciated. also this is a daily driver plus spl setup .
Old 10-16-2012, 01:51 PM
GPCustoms's Avatar
0/11 ssssss661
You're trying to fit all of this in the trunk of a sedan
Old 10-16-2012, 02:08 PM
Brand New Members
0/11 ssssssss4
lol yeah i had the other box in the trunk already. plus two kinetik 2400's and a sundown saz 4500 amp . so i already know it fits just trying to make it more user friendly
Old 10-16-2012, 02:21 PM
GPCustoms's Avatar
0/11 ssssss661
Personally I'd just get some beefier 12's, have them firing into the cabin and seal them off from the trunk. I just plugged in some numbers and you're at about 6.7 cubes before sub, port, or bracing displacement.
Old 10-16-2012, 02:36 PM
Brand New Members
0/11 ssssssss4
those subs can handle alot of power and considering i can do 150 db on the windshield from the trunk with the 1st box its a pretty good design i can do a 52 in the kick as well ima
Old 10-16-2012, 03:00 PM
GPCustoms's Avatar
0/11 ssssss661
I realize they take a lot of power. It just seems like you're choking the subs quite a bit, and firing the subs upward in trunk usually doesn't do well.
But by all means if you're happy with it, then don't let me convince you otherwise. Your system, not mine.
I wish you luck with the new box.
Old 10-17-2012, 12:08 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
downgrade to 4 10s at least.
Box request for mast240- just need finishing touches on design mast240 Box Requests 0 07-13-2011 12:20 PM
Finishing up SBN build at shop = videos dcarcstms Car Audio Videos 1 03-18-2011 10:14 PM
Finishing my Tattoo Bryan Off Topic Chat 3 03-27-2010 07:10 PM
Need some advice on finishing my system chinesemonkey91 General Car Audio Discussion & Questions 6 04-03-2009 04:04 PM
