Need help in making Enclosure design - Car Audio Classifieds!
Old 10-22-2012, 12:30 AM
Ali888's Avatar
0/11 ssssss674
Default Need help in making Enclosure design
Hi,
i need some one who can do it right
4 12's Square subs with 5krms for daily ground pounder in non walled setup.
can anyone pls chime in or suggest me , how to design it correct
>Should go Loud (sound that goes blocks away)
>Plays with authority the 28~50hz range Specially
>The build is for giving demo purpose as well
Maximum available space to work with
36"W x 21"H x 25"D
thnx
Digital Designs.....GrounD PoundeR!!!
Enclosure Design Ali888 General Car Audio Discussion & Questions 30 06-14-2012 03:25 PM
enclosure design help? exbar420 Enclosure Discussion & Design Construction Help 0 11-08-2011 11:06 PM
enclosure design hughesc9393 General Car Audio Discussion & Questions 1 10-20-2011 07:19 PM
Need an enclosure design. J31Rob Enclosure Discussion & Design Construction Help 6 06-01-2010 10:59 AM
making a ported fiberglass enclosure Patrick Simmons Sound Deadening & Fabrication 17 01-25-2009 09:18 PM
