series vs parallel 6th order - Car Audio Classifieds!
Old 10-22-2012, 02:28 AM
0/11 ssssssss7
Question series vs parallel 6th order
I have 4 Pioneer TS-W3004SPL running in a ported box at 37 hz off one mojo 4kw but looking at changing to a series or parallel bandpass in a Avalanche. I already started cutting wood for the parallel 6th order but thinking about going with a quasi 6th order. I have attached of what I am dealing with. Just trying to find out which one will have more pressure. Thanks in advance.
Old 10-22-2012, 11:22 AM
Infinitelybaffled's Avatar
0/11 ssssss816
I have never seen a parallel tuned 6th work....EVER. I'd go series tuned.
Inappropriate sig image.
Old 10-22-2012, 11:30 AM
0/11 ssssssss7
Thanks, I was wonder because there I have seen people start a parallel build but with no end results. It looks good on paper but had that last minute feeling about it. I think it might be suited for home better that car audio. With the series (quasi) 6th order, I am worry about the cone displacement and dg gain on the charts I have attached with box ratio.
Old 10-25-2012, 04:09 AM
0/11 ssssssss7
Started on project, just need to cut the baffles for subs and ports. The LF (rear) slot port 1 x 19 will be too small and have some port noise so might have to go with a square port for now. The other box is what I have currently in there.
Old 10-25-2012, 06:53 AM
Looks great! I would run a square port over a 1:19 any day, lol. That's just too narrow.
Old 10-26-2012, 03:43 AM
0/11 ssssssss7
What do you think about 33 x 1.5 x 19 L port for the rear chambers on each. I know that will cause more group delay. 11 3/8 x 19 (1 of 2) and 21 1/2 x 19 (2 of 2) to make L port. I will have about 7 inch opening left from the end of the port wall for air flow. Trying to see what is they best to run this port.
Old 10-26-2012, 06:43 AM
0/11 sssss1230
Quasi 6th is the way to go. Looking at your design, be sure to put a v in between the ports so they don't fire at each other. Also if you have to use a 19x1.5 port take 5" off the length. You won't be the best on the meter but you'll still sound great.
Team Excessive
Old 10-26-2012, 11:58 AM
0/11 ssssssss7
Thanks, it will only change my fb from 27 to around 28. you stated that I will not be the best on the meter but still sound good? Is that because of the narrow port or because of my passband range? I finally realized that it is hard to be tuned low vs being best on meter vs huge box vs big power amps (10,000 and above) and daily driver. Thanks in advance.
Old 10-27-2012, 12:46 AM
DBescort369's Avatar
0/11 ssssss200
Mine works great
Team Electronics Depot
Team xSPLicit
Old 10-27-2012, 12:56 AM
0/11 sssss5305
Pretty sure Yuey runs a parallel tuned 6th order and a21brava had one in his 300. Both of those got loud and move a LOT of air.
I run a series tuned and it works well, took a little trial & error to get it right. But I don't model shit either...
Wiring batteries in series vs. parallel. LEN671 General Car Audio Discussion & Questions 23 10-10-2012 02:08 AM
Wire one dvc speaker in series / parallel and other in parallel on mono amp? djkomplex General Car Audio Discussion & Questions 1 06-10-2012 06:53 AM
Series/parallel wiring Fatboy501 General Car Audio Discussion & Questions 6 02-12-2011 03:21 PM
Series/Parallel Wiring Question andes11 General Car Audio Discussion & Questions 11 09-21-2010 11:58 PM
Series/Parallel Wiring andes11 General Car Audio Discussion & Questions 10 09-13-2010 09:31 AM
