deisgned my first bandpass 3:1 2 18's blazer. opinions? - Car Audio Classifieds!
Old 10-24-2012, 09:34 AM
0/11 ssssss129
Default deisgned my first bandpass 3:1 2 18's blazer. opinions?
Well with all the talk about bandpasses i decided to give a shot designing one. Ive never built one or.designed one. I have built quite a few boxes though. I did come across one snag which ill bring up in a second. Rear chamber 6 cubes. 3 per sub. Front chamber is 18. Box dimensions are 38x31x44. Inside dimensions are 36.5x29.5x42.5 this will allow me to slide it in through the back then double/triple wall it after its inside. Port is 29.5x9 and 7" long which is 270 sq in at 44hz i believe? I know its a little on the low side but i mainly want it for lows.now my snag is that i cant fit the 18's side by side to do a flat wall for the rear chamber. And i heard of some claiming firing woofers towards each other causes cancellation.? But i dont want subs on one.side as port is in the middle of the.box so i was thinking one on each side inverted. I gave myself .4 for sub displacement and 1.4 for port. The box comes out to 26.4 then minus port and subs leaves me 24.6 im gonna try to avoid internal bracing and go with double wall and 2x4's. Any input on this box? criticism? Things i left out?
Louder Is Better!
Old 10-24-2012, 09:50 AM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
i would bug hackmunch with this for sure, or even add it to the already exsisiting 4th order thread. imo design dont really mean much without the proper subs, what you running
Old 10-24-2012, 09:51 AM
djscrubb's Avatar
0/11 sssss2332
also do a "v" so the subs arent right parallel to each other to avoid cancellation
Old 10-24-2012, 09:55 AM
0/11 ssssss129
I was actually hoping he would chime in on it. Subs are up in the air. Im just throwing around ideas before i actually pull the trigger. Im lookin at everything from psi, sundown, aa mayhems etc...
Louder Is Better!
thinkin of swapping my 18's for 15's..need opinions pls beatnbronco General Car Audio Discussion & Questions 15 07-26-2012 08:52 PM
2 18's in a blazer nmachado99 General Car Audio Discussion & Questions 4 06-09-2012 06:08 PM
4 18's in a 2dr blazer dcarcstms Car Audio Videos 13 01-15-2012 05:30 PM
Stay ported or try 4th order bandpass wall for 4 18's?? 46panel General Car Audio Discussion & Questions 7 05-17-2011 02:19 PM
18's in a blazer blazed_obsession General Car Audio Discussion & Questions 39 03-01-2011 08:25 PM
