box for sa12? need advice please - Car Audio Classifieds!
Old 10-25-2012, 07:32 PM
0/11 sssssss23
Default box for sa12? need advice please
i am trying to build 2 boxes for 2 sundown sa12s. the boxes will be going into a 2001 silverado extended cab, one behind each seat. here are my questions:
1) does this look right to you guys as far as cuft and tuning for the subs? i listen to lots of decaf and other rap music.
2) how would i adjust the cuts for sub and port facing up? is it as simple as building as pictured then turning the box? or is it an entirely different process?
Old 10-25-2012, 07:41 PM
0/11 ssssss220
For the love of God, DO NOT USE RE's box calculator.
The Following 2 Users Say Thank You to RESE15 For This Useful Post:
akrja_07 (10-25-2012), marcotheclepto (10-27-2012)
0/11 ssssss220
Put up a post in Sundown's sub forum.
Old 10-25-2012, 07:43 PM
0/11 sssssss23
lol i have heard that before. i have downloaded the torres one and also winsd but they are both extremely complicated for me... i have tried and tried but i can't figure those two out for the life of me.
Old 10-25-2012, 07:50 PM
0/11 ssssss220
There's a bunch of free box designs listed in this sub forum. It says Free Box Designs. Find one about 1.5 to 1.75 cu/ft tuned to whatever you'd like, I suggest 33 or 35 hz. Build it, take pictures and share with the class.
Old 10-25-2012, 08:03 PM
Mr.G6's Avatar
0/11 sssss4614
also need more port area looks like that image says 1.5" wide port.. but im also 1/2 blind.. but nonetheless the re calculator is horribly wrong
stick with the 12 to 16" of port per cubic foot
i like to use 14 to 15" per
2000 Gmc Sonoma ext cab
Old 10-25-2012, 08:16 PM
0/11 sssssss23
i glanced real quick, the thread i saw was all designs on page 4, but they werent listed as to size and tuning... i may have missed something though.
yeah its 1.5 lol... that seamed small to me also but even if i open it up even half an inch, it takes the tuning way up, close to 40 i think it was... im going to give the torres another shot, that ones good right?
Old 10-25-2012, 08:26 PM
Mr.G6's Avatar
0/11 sssss4614
when you make more port area the length inside the box needs to be longer
then that will take up more internal volume and ull have to make the gross measurements bigger
torres works good yes but i find it hard as hell to understand
Old 10-25-2012, 08:41 PM
0/11 sssssss23
lol yeah im too much of a noob to use that program i am clueless. i guess i will go sealed for now, it seems way easier.
Old 10-25-2012, 08:49 PM
0/11 ssssss220
Don't go sealed. Neither you or your sub will like it. It'd ne worth it to pay RAM Designs or Surreal the few bucks to design an enclosure specifically to your needs.
Need input on sa12 box before I build it k3n12ock (Sundown Audio) 17 01-25-2013 05:33 PM
Advice on box design HazeGrey75 (DC) 2 02-26-2012 11:23 PM
SA12 Aero box question k3n12ock (Sundown Audio) 10 08-12-2011 09:27 PM
Need box design/advice/BOTH EclipseChris Enclosure Discussion & Design Construction Help 1 02-03-2011 08:36 PM
Sundown SA12 + Prefab Box laserred97gt 12" Subwoofers 15 12-28-2010 02:42 AM
