what table saw blade to get? - Car Audio Classifieds!
Old 10-31-2012, 10:39 AM
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
Default what table saw blade to get?
I just recently aquired a table saw and been using it.... makes building so much easier and fun.
But its time to replace the blade.
Any suggestions on what to get.
I was thinking something with 40 or 60 teeth and the anti kick back thing.
Some are quite pricey...
mine is 10"
you probably wont like me
Old 10-31-2012, 10:43 AM
0/11 sssss2011
Feedback Score: 61 reviews
the only one i use is the 80 tooth Diablo. it cuts everything clean including plexi, goes through like a hot knife in butter. only get a 60 tooth or less is you are just ripping long cuts of MDF. if you plan on cutting multi-layer birch or want a good clean finish, you should be getting more than 60 tooth.
http://www.homedepot.com/h_d1/N-5yc1...1#.UJFHKbQvE20
Old 10-31-2012, 10:45 AM
upzaw2000's Avatar
0/11 ssss14427
i saw those at northern tool for about 30 bux . You like it?
0/11 ssssss816
Feedback Score: 22 reviews
I have had good luck cutting mdf with cheaper carbide tipped blades, but when cutting birch ply, they warp and go dull pretty quickly.
The Following User Says Thank You to jstang2003 For This Useful Post:
upzaw2000 (10-31-2012)
Old 10-31-2012, 10:47 AM
0/11 sssss2011
love it, will not get anything else. it just goes though the wood so easy and makes the cut so smooth with no burn marks or anything.
The Following User Says Thank You to fasfocus00 For This Useful Post:
Old 10-31-2012, 10:53 AM
upzaw2000's Avatar
0/11 ssss14427
Really.. interesting.
MDF will be what i am using mostly. willing to accept the weight issue now instead of fighting the grain and working with MDF is so much easier later on with sanding and painting.
sweet! awesome thanks!
yall have any luck with those kerf blades... i cant remember what they are called but can do 1/2"(example) wide depth cuts
Old 10-31-2012, 10:59 AM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Its a dado blade, yep i use them all the time to dado and rabbet. They work great if you dont wanna have to move the fence 1/8" to make the same cut.
Sent from my PG86100 using Tapatalk 2
The Following User Says Thank You to btsteinb For This Useful Post:
Old 10-31-2012, 11:02 AM
upzaw2000's Avatar
0/11 ssss14427
u have any suggestions on dado blades. Not sure what to look for
Old 10-31-2012, 11:05 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
I second Diablo. As far as Dado's your looking at probably $60-$80 for a decent entry level set.
0/11 ssssss697
go with a Diablo. I run Diablo in all my saws and love em
Saw blade jessdabest77 General Car Audio Discussion & Questions 6 01-29-2012 12:56 PM
blade amp jezus43130 General Car Audio Discussion & Questions 9 08-24-2011 09:40 AM
table saw blade suggestions da box king Enclosure Discussion & Design Construction Help 22 03-15-2010 01:26 PM
circ blade gbo559 Enclosure Discussion & Design Construction Help 12 02-15-2010 04:57 PM
ninja blade for PC lil_italy773 Movie & Gaming Review 7 02-14-2010 07:52 PM
