Sa-8v1 in center console - Car Audio Classifieds!
Old 11-01-2012, 11:51 AM
garygross7's Avatar
0/11 ssssss305
Default Sa-8v1 in center console
Going to build a custom center console for an sa-8v1. Goal is to have the amp also hidden in the enclosure as well because I don't want to hide it under a seat. It is going to be in a 2000 ford explorer. Was wondering if I should do I 4th order or 6th order. Here are some pics. Has a nice little rubber boot that was hiding a cut to the bottom of the car so will be perfect for running wire. ImageUploadedByTapatalk1351788671.346713.jpgImageUploadedByTapatalk1351788687.155342.jpg
Old 11-01-2012, 12:03 PM
Mr.G6's Avatar
0/11 sssss4614
putting the amp INSIDE the enclosure.....no
2000 Gmc Sonoma ext cab
Old 11-01-2012, 12:21 PM
garygross7's Avatar
0/11 ssssss305
I'll mount it under and have the enclosure a couple inches lifted up
Old 11-01-2012, 07:40 PM
garygross7's Avatar
0/11 ssssss305
Opinions welcome
Old 11-21-2012, 10:58 AM
0/11 ssssss267
I did something very similar in a dodge caravan. Down fired the E8, mounted amp on the baffle as well, ported to rear, sub/amp is about 3" from floor. Sounds pretty good, have a console now and everything is out of site. All worked out well. Wished I had went with a bigger amp but just used what I had to gain some sound in the ole van.
Old 11-21-2012, 11:00 AM
0/11 sssss3842
we ended up scrappin the idea of a center console as it just wasnt wide enough. I talked him into using the free 6th order design. sounds and looks good.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 11-21-2012, 11:01 AM
0/11 ssssss267
Do you have a picture of the install? Did you go with the low tuning or high output?
I was looking at that enclosure for the santa fe and considering it.
Old 11-21-2012, 11:06 AM
0/11 sssss3842
Yea these are the ones the owner took. I built the box, he painted.
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 11-21-2012, 12:13 PM
0/11 ssssss267
Cool, looks good. Thanks for sharing.
Was that the low or high output version?
Old 11-21-2012, 12:14 PM
0/11 sssss3842
high output
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Need help on a center console RetroAudioInc General Car Audio Discussion & Questions 15 02-07-2013 06:13 PM
2 L7's in a center console KNOTDUDE Car Audio Videos 4 04-11-2012 03:19 PM
Center console box kunzy420 Enclosure Discussion & Design Construction Help 3 03-14-2012 03:43 PM
center console sub box? 98Expo General Car Audio Discussion & Questions 4 08-12-2010 01:20 PM
Mounting a sub in my center console tahoebrotha General Car Audio Discussion & Questions 10 12-29-2009 04:52 PM
