Any changes for my 18" enclosure? - Car Audio Classifieds!
Old 11-01-2012, 02:16 PM
0/11 sssssss97
Default Any changes for my 18" enclosure?
Box is for a DD 9518 on about 2000-2500 watts. Going in the back of a ford explorer.
The specs are exactly as the DD website suggests, so im just wondering if anyone knows of any slight changes or tweaks to make it a little better. Also should I go with DDs suggestion of Sub back/port back or make mine sub up/port back?
Kind of noob question but if I changed the design to be sub facing up, do the inner port walls need to be relocated or redirectioned? Hope that makes sense.
Thanks for your help starting build tomorrow hopefully.
EDIT:
OK well I have a few more questions.
Having someone else build it instead, I gave him the exact link of the DD box designs, except I told him to put the sub on top, double baffle, and 45's on the inside. He told me if I wanted the Sub on top he would have to 'modify' the inside port wall or something. This scared me because I think he was trying to center the subwoofer cut out or something?
The best way would be to leave the sub towards the top left side of the box correct?
Also if I take that design and add 45s on the inside, do I have to recalculate the NET volume because that would take away some internal airspace right? Thus changing my tuning, etc. Or does that not really matter?
Sorry for the noob questions
Old 11-01-2012, 02:24 PM
Mr.G6's Avatar
0/11 sssss4614
subs up port back or subs and port up work best in suv's
and no looks like fromt he picture u can just put the sub hole on top itll clear the port n such
make sure u brace the box and do double baffle to hold that woofer
2000 Gmc Sonoma ext cab
Old 11-01-2012, 02:34 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
biggest myth i ever see as a designer right here.
Old 11-01-2012, 02:37 PM
Mr.G6's Avatar
0/11 sssss4614
really? thats why 98% of people do it this way
ive seen and heard 3 sub and port back setups and they were total fail and it wasnt the box specs etc..strictly orientation of the enclosure
he literally removed a baffle and made sub on top and gained around 2 db
i only speak from my personal experience and believe me ive made over 50 suv boxes
Old 11-01-2012, 02:39 PM
0/11 ssss31257
myth my ass!
it's not quite as simple as it sounds but sub up port back loads the sound into the SUV more than just about any other way you can arrange it.
Mr.G6 (11-01-2012)
Old 11-01-2012, 02:45 PM
Mr.G6's Avatar
0/11 sssss4614
Originally Posted by iamsonic View Post
myth my ass!
finally somebody who knows wtf they are talking about lol
sub up port back OR subs and port up are the very most common designs you will see
ive never heard a good sub and port back design
Old 11-01-2012, 02:47 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
you have no clue who i am do you? hell i guess me and skip are doing our suv's very wrong to be getting so loud rear firing. explains why i cant do trunk cars either.
Old 11-01-2012, 02:50 PM
Mr.G6's Avatar
0/11 sssss4614
honestly skip01 is the only person ive seen use sub and port back..
Old 11-01-2012, 03:03 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
you must not go out much. Its much more than "Oh i has suv lets make it simplez like errybody else" hell i know alot of suv builds that failed sub up port back .... you cant just say its good.
Old 11-01-2012, 03:07 PM
Mr.G6's Avatar
0/11 sssss4614
well from the enclosures ive built for customers
sub and port back suckd badly compared to subs up port back config
all the loud suv's i see either on this forum or whatever are sub up port back
like taylorpro with the 4 sa 12s 46panel when he had the 4 18s or the dude with i think 8 sa15s that i think dj did...
and the list goes on and on and on and on with sub up port back config
2 Q's: "Adding" Wood To Fiberglass Enclosure & insulating carpet? 05LGT Enclosure Discussion & Design Construction Help 4 05-03-2012 10:36 AM
Brand New dual 12" custom enclosure 37"x22"x14.5" rachidfunaki Wiring, Electrical & Other Installation Equipment 8 09-04-2010 07:56 PM
WTB: 8" or 10" Sub w/ Plastic Enclosure for Boat - Bazooka or Kicker for Example SAABsonic Wanting to Buy (WTB) 5 05-28-2010 11:22 AM
Mid/Tweeter "cups"/"covers"/"enclosure"/"etc"??? oxsign General Car Audio Discussion & Questions 11 04-21-2010 04:29 PM
[SOLD] 15" ported enclosure 4" aero ports gbo559 Wiring, Electrical & Other Installation Equipment 3 01-05-2010 12:01 AM
