Box question - Car Audio Classifieds!
Old 07-16-2009, 10:32 PM
0/11 ssssss111
Default Box question
Im trying to figure something out now i called dj @ aq for box specs on the hdc312-a now i was messing a round with some dimensions and im tryin to get 5 cubic ft gross int 64 sq inches of port area with a 20" long port heres what i got 12"h x 41"w x 24" d= 5.4 cubic feet12"h x 40"w x 23" d= 5.03 cubic feet what do u guy think
Old 07-16-2009, 10:34 PM
honestly I would do 4tf tuned to 35hz with 80" of port
it will play flatter and sound better on all types of music
and before you ask I have aq's myself the recommended box has a pretty big spike at 40hz - 50hz
Old 07-16-2009, 10:39 PM
0/11 ssssss111
So how big of a box should i build a 5 cube or was
Old 07-16-2009, 10:41 PM
I'm not sure what you are asking exactly
a 4ft box will take more power and play smoother all notes will be close to the same amplitude
the 5ft box between 40-50 it will get louder than the rest of them
0/11 ssssss111
So what ur saying is 4 cubes is better
Old 07-16-2009, 10:43 PM
0/11 ssssss111
Ok i got u now what should i change the port to
Old 07-16-2009, 10:45 PM
80" port in a 4ft box needs to be 36.5" long you can bend it if needed
Old 07-16-2009, 10:49 PM
0/11 ssssss111
I got it so that 80 sq inches of port area and the port must be 36.5" long thanks wenn for the help
Old 07-16-2009, 10:50 PM
yeah it will tune it to lik 35.2hz which is close enough to 35 that you would never hear the difference
Old 07-16-2009, 10:53 PM
0/11 ssssss111
Ok thanks bro for all the help im going to try to build this my self
Question Bologna General Car Audio Discussion & Questions 20 06-03-2009 04:08 PM
Got a question about my sub Sunnyx General Car Audio Discussion & Questions 6 05-11-2009 08:10 PM
Sub Question Blackout General Car Audio Discussion & Questions 17 02-06-2009 06:53 PM
box question natisfynest General Car Audio Discussion & Questions 18 01-11-2009 07:40 PM
