2010 Impala box help. - Car Audio Classifieds!
Old 11-04-2012, 08:54 PM
0/11 ssssss151
Default 2010 Impala box help.
Anybody have general measurements of what I can fit? I'd like to make it as wide as possible and tall to minimize the amount of trunk it takes. But no biggie.
Just need 3 cubes air and whatever port needs to be. 35Hz
Any help is appreciate and I can toss a few bucks of any designers have worked on these vehicles. 2010 impala. I can give more details if interested
Thanks in advance. And I did search
Old 11-05-2012, 05:34 AM
0/11 ssssss216
I have an 07, not sure if the body style has changed much width wise I know it still looks pretty much the same. What size sub/subs are looking to put in?
Old 11-05-2012, 06:01 AM
0/11 ssssss216
Twelve's won't be a problem ported, you could even do a pair of 15' sealed without an issue but if your looking to do 15'ported just a heads up you could get away with one without much of headache but I went with two and got them in but I had to port the rear deck subs forward firing into the cab and it was a task. The end result was good it sounds great I'm happy with it but probably would do a pair of 12's or a single 15 if had to do it again.
Old 11-05-2012, 06:31 AM
0/11 ssssss749
Feedback Score: 21 reviews
I'm goin to do 2 15s ported through rear deck off 5k wanted to try 4 12s but not enough room for it plus batts n amps
Old 11-05-2012, 06:38 AM
0/11 ssssss151
Yep 07 is the same. And was thinking on 2- 12s
Box for a 70's Impala, 4 Audiopipe 12's jt_buck General Car Audio Discussion & Questions 18 12-01-2011 10:56 PM
Box for a 62 Impala jt_buck General Car Audio Discussion & Questions 10 11-08-2011 10:28 PM
T2000 15 box tuning/design thread for 2010 lancer trunk siucsaluki11 General Car Audio Discussion & Questions 9 12-27-2009 04:15 PM
a box for a solo x 18 in a 03 impala More spl Enclosure Discussion & Design Construction Help 3 12-13-2009 11:38 PM
