anyone ever do a 4th order PR? - Car Audio Classifieds!
Old 11-07-2012, 01:18 AM
GiGLZ's Avatar
0/11 ssssss514
Default anyone ever do a 4th order PR?
some people will try to call it a 6th, but i figure depends on what part of the 4th you PR
my last enclosure was for a single 15"... sealed part was 2 cu and ported part 3.6 cu tuned to 43 hz... lots of bandwidth with it.. 25 to about 53hz..
one of my new projects i figure same sub but down to 1.8 cu sealed and 3 cu in the "ported" area that will house 2 x 12" PR's...
this will allow me to adjust tuning on the field to allow me to compete in idbl and bassboxing, i figure.. also it will save me from using lengthy aero ports ..
anyone try something similar before?
Old 11-07-2012, 01:20 AM
0/11 ssss31257
a 4th order with PR is as they call it 'a series tuned 6th order'
should work fine but I'd just use a port instead of the passive radiator.
Old 11-07-2012, 01:40 AM
GiGLZ's Avatar
0/11 ssssss514
dont see how it is considered a 6th...sealed rear chamber and front chamber PR'd...
if the sealed rear chamber was ported or PR'd, it would be a 6th
i need to spare some room for more batts and amps so if i can get away with saving some space along with no port noise, adjustable tuning, etc..why not? but all in theory or ?
Old 11-07-2012, 01:42 AM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
it would be a 4th. never seen it done though.
so you would have a normal 4th, but instead of the port you have a pr.
I say you should try it. Sounds cool and different.
Old 11-07-2012, 01:45 AM
0/11 ssssss169
Make sure you do a build log.
Old 11-07-2012, 02:03 AM
0/11 ssss31257
I don't read. I assumed the PR was in the rear chamber firing into the front chamber.
yeah, I talked about this on 10/20/12 for a different reason.
using passive radiators to keep the magic smoke out of your car.
Old 11-07-2012, 02:43 AM
GiGLZ's Avatar
0/11 ssssss514
think ill give it a go.... it will be one of the first builds for next season... wanted to do a folded horn for either a single 12 or maybe the 15 if i can make it fit.
Old 11-07-2012, 11:27 PM
0/11 ssssss195
You wouldnt happen to have the design of your 15" 4th order would you? Id love to know what sub and what it looks like. I have a thread in here about a crossfire in a 4th I'd like to try.
This idea you have^^^^ seems really sick if it works
Old 11-08-2012, 12:08 AM
GiGLZ's Avatar
0/11 ssssss514
here are some pics... iirc it was 2 cubes sealed and 3.6 cubes ported to 43hz.
Access panel for 4th order
sub i used and am using for this project can be viewed here along with my build
GiGLZ 04 Toyota Echo 2012 Build
Old 11-12-2012, 06:22 PM
GiGLZ's Avatar
0/11 ssssss514
Finally finished the design as well as other people's designs today...
Main driver = 15" GiGLZ - 6k Daily Subwoofer
PRs = 2 x 12" PSI PRs
Was going to do the PRs side by side, but it would increase my PR chamber by quite a bit..
1.8 cu ft sealed
3.45 cu ft "ported"/PR chamber --> I could not go any smaller or wont be able to install/remove the main driver out of "viewing" window made of 1" thick lexan
Please leave any feedback..
4th order or 6th order sundown General Car Audio Discussion & Questions 2 06-14-2012 07:55 PM
