forgot how to calculate for 45s in a box - Car Audio Classifieds!
Old 11-07-2012, 09:32 PM
0/11 sssss8594
Feedback Score: 55 reviews
Default forgot how to calculate for 45s in a box
i just drew a blank on this so im looking for help...how do i calculate for 45s??...i kno that 2 45s equals a square so i would find the area of that square...but how do i transfer that into sq ft?...or is it cubic ft??...this is where i get lost
Enclosures
Old 11-07-2012, 09:39 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Do inches x inches x inches /2 thats cubic inches. To convert to cubic ft divide by 1728.
Sent from my PG86100 using Tapatalk 2
Old 11-07-2012, 09:41 PM
0/11 sssss8594
why am i multiplying inches three times??
Enclosures
Old 11-07-2012, 09:47 PM
btsteinb's Avatar
0/11 sssss3573
Length width height.
You are gettin the surface area of the triangle. Base x height /2.
Times how long it is.
Old 11-07-2012, 09:56 PM
GPCustoms's Avatar
0/11 ssssss661
assume a thickness of zero, go to wedge calculator 1
Subwoofer Enclosure Calculators, Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators
Team Showtime Car Audio
Old 11-07-2012, 10:04 PM
0/11 sssss8594
Originally Posted by GPCustoms View Post
and i would just use that times however many 45s i use??..or is there more math for each one?
Enclosures
Old 11-07-2012, 10:12 PM
btsteinb's Avatar
0/11 sssss3573
if they are all the same size, yes.
if not then you need to do a separate one for each 45 that is different.
Old 11-07-2012, 10:15 PM
0/11 sssss8594
awesome..this is soo much easier than what i was doing before...less math for me to do...lol
Enclosures
Old 11-07-2012, 10:24 PM
GPCustoms's Avatar
0/11 ssssss661
Some pretty general numbers I've found:
a 45 with a 3" hypotenuse (width): other two sides 2 1/8" each: displaces approx .02 cubes @ 12" height
a 45 with a 4 1/4" hypotenuse (width): other two sides 3" each: displaces approx .03 cubes @ 12" height
Check my math though. It's been a while.
Old 11-07-2012, 10:27 PM
0/11 sssss8594
i usually try to use 3" x 3" 45s...then whatever the length i need
Enclosures
Box Building use 45s or no? 98GCLimited Enclosure Discussion & Design Construction Help 50 06-17-2012 08:21 AM
forgot to brace top of box need help securing it darkkon Enclosure Discussion & Design Construction Help 20 05-05-2012 08:05 PM
How to calculate Volume for a fiberglass box ? drsnazzy General Car Audio Discussion & Questions 4 12-17-2011 04:29 PM
Woodgrain box? 45s/Rounding? Help. Matt3824 Enclosure Discussion & Design Construction Help 1 11-20-2011 09:47 PM
How to calculate weird box size?? Stay sealed or go ported? westman995 General Car Audio Discussion & Questions 8 08-13-2009 12:41 AM
