my first design. Help plz - Car Audio Classifieds!
Old 11-10-2012, 01:27 PM
soundstream88's Avatar
Awaiting Confirmation
0/11 sssss1539
Feedback Score: 22 reviews
Default my first design. Help plz
I tried designing a temp box for in my blazer until we start the new wall in feb. Will this work? It is for 2 15" AQ's on a us amps 3200d. The entire back of my blazer is all wood. ceiling and sides. Should I fire port a different way?
Old 11-10-2012, 02:01 PM
0/11 sssss1539
all side are doubled up of 3/4" mdf
Old 11-10-2012, 02:42 PM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
No real reason to double up on everything imo. Id double up only the top baffle.
As far as port, firing back works great in most all SUVs as well subs configuration works good firing up although I have not seen many lose by firing forward or back. I think the port placement is much more important.
Old 11-10-2012, 03:42 PM
0/11 sssss1539
will the dimensions work? and my tuning?
Old 11-10-2012, 04:52 PM
Looks like about 17.5 ft^3. That's freaking huge for two 15s, but I like big boxes. Port area looks small at 96 in^2. That would only be a few inches deep for a mid 30's tuning. Open it up a bit and increase port depth, although you might be fine depending on the sub's displacement.
Old 11-10-2012, 05:02 PM
do 7ft tuned to 37hz, 3 6" pvc pipes.
my box was triple baffle, double walls.
39x17x33 it will fit very tight between the wheel wells but will fit. also how did you get those dimensions for a 4 door blazer?
The Following User Says Thank You to korey_hofer For This Useful Post:
soundstream88 (11-14-2012)
Old 11-10-2012, 05:06 PM
0/11 ssssssss7
Are you unable to test the different ways?
Old 11-10-2012, 05:10 PM
0/11 ssssss816
I don't think he's too worried about the numbers it does if he's putting a wall in it in a couple of months. Probably just wants some tunes for the time being
Old 11-14-2012, 01:19 PM
0/11 sssss1539
yeah just something to beat on till we get going on the new wall.
Plz Help! KcRidin09 General Car Audio Discussion & Questions 8 03-23-2010 07:35 AM
Plz help. KcRidin09 General Car Audio Discussion & Questions 6 03-22-2010 04:14 PM
DB-r help plz 92K1500 (db-r) 12 01-19-2010 11:49 AM
i need an 18" basket plz someone plz mmatsjugg Wanting to Buy (WTB) 11 01-16-2010 03:13 PM
plz help!!! Lance_aka_64 General Car Audio Discussion & Questions 4 04-24-2009 10:47 PM
