Sub placement in relation to port ????? - Car Audio Classifieds!
Old 07-18-2009, 05:57 PM
worstenemy453's Avatar
Veteran Member
0/11 sssss4401
Default Sub placement in relation to port ?????
My port is all the way to the left of my box. Should i put all my subs grouped together on the right or would it be ok to have them evenly spaced with one sub close to the port and one far away from it.
2005 Toyota Tundra Double Cab
Sub: ---
Speaks: ---
Headunit: ---
Street Stars Motorsports - All Thing Performance/Custom.
Old 07-18-2009, 06:15 PM
scfaust's Avatar
0/11 ssssss848
i was told no because all subs wouldent load the same but im no expert so im just telling what i was told
Old 07-18-2009, 06:21 PM
Veteran Member
0/11 sssss4401
so i need to put them all on the right side.
Sub: ---
Speaks: ---
Headunit: ---
Old 07-18-2009, 09:10 PM
Veteran Member
0/11 sssss4401
Spy, can you weigh in on this.
Sub: ---
Speaks: ---
Headunit: ---
Old 07-18-2009, 10:42 PM
0/11 sssss1560
x2
You want all the subs the same distance from the port for optimum portage. Otherwise they will behave differently. But I'm not a box building expert either.
Old 07-18-2009, 10:47 PM
Veteran Member
0/11 sssss4401
Originally Posted by MaTT6387 View Post
x2
Im waiting for Spy to come in with the expertise but when 2 people say something in a knowledgeable place like this i have no reason to really doubt them.
Sub: ---
Speaks: ---
Headunit: ---
Old 07-18-2009, 11:30 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
If you are using a box with a lot of port area placing one far away from the port and one close to the port opening will cause the one closer to the port to unload.
this is much less of an issue with properly sized ports although I would still try to avoid placing a sub directly in the port opening.
Can you post up a pic of your box or design for us to help you figure it out.
/ CAAA Member #2 /
Old 07-18-2009, 11:36 PM
Veteran Member
0/11 sssss4401
I built the box myself with no design. my port is a 3" Aero external flared. One sub is about 35" away from the port and one is about 6". My box is right around 42" long, i cant get a picture at the moment but my port is all the way to the left so ill just line my subs up all the way to the right.
Sub: ---
Speaks: ---
Headunit: ---
TL meter placement forceww General Car Audio Discussion & Questions 13 07-04-2009 02:13 AM
port Fosgate1 Enclosure Discussion & Design Construction Help 3 07-02-2009 06:18 PM
Subs in Cars...Woofer Placement BassikInstincts Enclosure Discussion & Design Construction Help 4 01-28-2009 02:16 PM
Comps 6-1/2 Staging/Placement Blackout General Car Audio Discussion & Questions 9 01-12-2009 03:55 AM
