Help me design my Box!Got all max Dimensions! - Car Audio Classifieds!
Old 11-14-2012, 01:48 PM
0/11 ssssss114
Default Help me design my Box!Got all max Dimensions!
Finally got the console out of my truck and the max dimensions for my box are 15 wide,20 long, and 18inches tall. I have a sundown Z v.2 12 thats going in it and what do yall think I should do as far as sub and port placement. Ive tried doing slots in torres but I never can get it tuned down to 32 like I want. Please help. Here is a pic of the space.
Old 11-14-2012, 02:01 PM
SPL-MěNST3R's Avatar
0/11 ssssss201
which direction do you want the sub and port to go?
Old 11-14-2012, 02:13 PM
0/11 ssssss114
thats what I need help with. Probably sub facing back seat be I dont know which way the port should then go. I could also do the sub inverted facing toward the front.
Old 11-14-2012, 02:27 PM
0/11 ssssss201
Do you want to see the sub? you could go downfiring w/ port firing back.
Old 11-14-2012, 02:40 PM
0/11 sssss1286
Let me know if i can be of assistance .. PM me and i can get u a design going
Old 11-14-2012, 02:44 PM
newarkbeast973's Avatar
0/11 sssss7810
^ hit this guy up! You won't be disappointed!!
New build coming soon!!
Old 11-14-2012, 03:53 PM
I've seen good results with the port forward or port backward with the sub down-firing. I would build a small test box with some scraps and a piece of 4" PVC and try it in a few different directions before you settle on something.
Old 11-14-2012, 04:11 PM
0/11 ssssss114
I think downfiring would cut my volume down too much since the box can only be 18inches off the floor and if I left space for excursion, my actual box would only be like 15in. Tall.
Sent from my SCH-L710 using Tapatalk 2
Old 11-14-2012, 04:19 PM
0/11 sssss1286
Need to get creative with ur measurements and u can fit a down firing box
u may need to add some angles to get it like this
The Following User Says Thank You to dcarcstms For This Useful Post:
newarkbeast973 (11-14-2012)
Old 11-14-2012, 04:32 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Posting kyles box isnt fair. That thing is the best center console build ive ever seen.
Sent from my PG86100 using Tapatalk 2
Help w/ box dimensions josh09 Build Logs 2 03-11-2011 07:48 PM
Max Dimensions For a subwoofer box in an Eclipse DevinG17 General Car Audio Discussion & Questions 0 10-21-2010 10:02 PM
Box Dimensions whitedragon551 Enclosure Discussion & Design Construction Help 0 07-21-2010 12:02 PM
Need Help with Box Dimensions! ivegotadiamondhp10 General Car Audio Discussion & Questions 0 05-04-2009 01:17 PM
ported box dimensions?? jimthecarguy Enclosure Discussion & Design Construction Help 1 01-03-2009 12:23 PM
