Need more port/modifying current box. pictures inside ;) - Car Audio Classifieds!
Old 11-15-2012, 07:07 AM
mxvris's Avatar
0/11 sssssss33
Default Need more port/modifying current box. pictures inside ;)
Ok, after talking to a few people they all say the same thing. I don't have enough port. I would really love to build a 4th order but with the cold coming I've decided to wait until spring. So for the time being I would like to modify my current box for increased port area and lower tuning.
Here's the current box specs Width-37" depth-39" height-12.5
All 1"MDF with 1.5" on the top.
Ideally I could remove the back piece where the aero's are currently mounted and build a standard port. The box is currently tuned at ~34. I would like to be closer to 30.
Any ideas?
-Build in progress-
Pioneer deh-6000
AB VFL 500.1 @.5
(2)15" Zv1's w/ NS parts
tenney alt
DIYMA 1/0 3+/2- runs
4 batteries and counting...
Old 11-15-2012, 11:41 AM
That's going to be a looong port, somewhere in the neighborhood of 30". My suggestion would be to seal up the side that has the aeroports on it now and put a slot port on the bottom of the box on the other end, so that the new port would terminate on the end that has the aeroports now. Then turn the whole thing around so that the subs are further back and the new port is firing back.
Old 11-15-2012, 11:52 AM
Matt3824's Avatar
0/11 sssss3754
X2
Old 11-15-2012, 12:35 PM
Anton Miller's Avatar
DoucheMiller
0/11 sssss3720
those 15's? single six is fine.... box might be too big tho
1997 CHEVY CAVALIER - BUILT FOR EFFICIENCY!! YOUTUBE:
This box or that box (pretty pictures inside!!) SPLEclipse Enclosure Discussion & Design Construction Help 10 08-13-2012 05:44 PM
Crazy Air Movement! A demo & a girl inside the port of the 6 18's box 46panel Car Audio Videos 19 11-07-2011 01:03 PM
Aero port distance from inside box question 528hz Enclosure Discussion & Design Construction Help 7 10-15-2011 04:35 PM
A few pictures of my other hobbie BMX. (BEWARE SASQUATCH PICTURES INSIDE) dat517boi Sports and Fitness 6 12-20-2010 05:30 PM
Wanting ideas of a new box for 3 18" Death Penalties (pic of current setup inside) 46panel General Car Audio Discussion & Questions 89 09-03-2010 12:51 PM
