4th order response - Car Audio Classifieds!
Old 11-16-2012, 12:22 PM
Brand New Members
0/11 ssssssss3
Default 4th order response
Hey everyone I recently built a new "wall" 4th order but its not sealed off quite yet. Right now, it pounds everything under 30-33hz. Actually under those frequencies I hear more mechanical noise than I do the actual frequency.
Could it be an issue with my enclosure or will it improve when I seal it off?
(Specs are 3:1 4th order with the baffle and loading wall parallel to each other. Magnets are about 4" from the port entrance. 18in per ft of port 210in 7.25in long. 4 sealed 12 ported
Old 11-16-2012, 12:32 PM
infaredsinsor's Avatar
0/11 ssssss769
4th orders why are some people so quiet with them?
Subs, amps, and power
AFEX Fire Suppression Systems Quality Engineer
itrader info available on profile
Old 11-16-2012, 12:34 PM
0/11 sssss1286
Where is our tunning and what subs ?
Old 11-16-2012, 12:53 PM
Brand New Members
0/11 ssssssss3
I already read that entire thread. Helped a ton
The tuning is a little under 50hz
Old 11-16-2012, 12:56 PM
Brand New Members
0/11 ssssssss3
Subs are 15" sundown zv3s
Old 11-16-2012, 08:04 PM
I noticed a similar effect with mine. Below 27/26hz I can't "hear" much, but everything is flexing like crazy. I know I'm loosing a lot of pressure around my loading wall too, as I can see the headliner get sucked back where it leaks, lol.
4th order 6th order. btsteinb General Car Audio Discussion & Questions 1 11-13-2011 08:18 PM
