critique this design! - Car Audio Classifieds!
Old 11-16-2012, 10:23 PM
0/11 sssss3842
Default critique this design!
Threw this together for 2 Kicker Comp 10s. subs up port out side. Any constructive criticism?
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 11-17-2012, 06:17 AM
0/11 sssss3842
Anyone?
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 11-17-2012, 01:05 PM
0/11 sssss3842
would really like some feedback before i build!
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 11-17-2012, 01:15 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
shrink the port a little bit to about 30in^2 and it should be good.
Old 11-17-2012, 10:22 PM
0/11 sssss3842
Anyone else?
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 11-18-2012, 02:39 AM
Looks good to me. Like Crazy said you could shrink port area down if you want. I don't think it would be necessary though, that's already a pretty big box for two 10"s.
It looks like (what I assume is your depth) is 13.5" outer, and your port width will the 3.5". That leaves you with 13.5 - .75 (front wall) - .75 (back wall) - .75 (port wall) - 3.5 (port width) = 7" of depth. That should be fine, but just something to think about clearance wise.
Old 11-18-2012, 06:22 AM
0/11 sssss3842
Recommended is 1.24-1.75 cubes per.
Mounting depth is 5" so should be ok.
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 11-18-2012, 07:52 AM
Mr.G6's Avatar
0/11 sssss4614
looks good
like said before only thing is i would shrink the port down to around 14" per or 13.5" per cube
14.8 is a bit much for a low xmax single spider woofer
2000 Gmc Sonoma ext cab
Critique wanted jwiLx General Car Audio Discussion & Questions 11 10-05-2012 12:36 AM
need critique on first box desgn KCowboy620 Enclosure Discussion & Design Construction Help 11 01-13-2012 05:04 PM
2 12s 4th order design critique Kelocyde Enclosure Discussion & Design Construction Help 26 12-06-2011 06:49 AM
Please critique my resume. rideit Off Topic Chat 1 05-25-2011 01:21 AM
Critique? F3M4 Enclosure Discussion & Design Construction Help 19 09-30-2008 10:47 PM
