Made Enclosure in Sketchup, Give me Opinions! - Car Audio Classifieds!
Old 11-19-2012, 09:37 PM
0/11 ssssss114
Default Made Enclosure in Sketchup, Give me Opinions!
So I have been asking and asking about console boxes for my F250. I finally went in sketchup and this is what I came up with. I have 2 or 3 more designs but I think this one is the closest to what I want. It is still a little bit big for My Sundown Z v.2, but I am only running it on a sax1200d. Do yall think I should add some things to the inside to get volume down, just leave it as is, or do a whole other design?
I hand calculated the volume and got 2.38 ft^3 after sub displacement and port displacement.
The port is 10inches wide by 2.5inches tall by 28inches long which puts this tuned right at 30 hertz I think.
Old 11-19-2012, 09:55 PM
0/11 sssssss21
If you are overpowering the sub, it's usually not a good idea to make the box too large else you may run jnto the subs mechanical limits. You can reduce volume by adding 45s or by adding some known shape (braces, etc) to the inside.
If I were you, I would calculate the actual box area of the sides, then divide that by your optimal airspace in cubic inches to give your exact width of an optimally sized box with that same cross section.
Old 11-19-2012, 10:00 PM
0/11 ssssss114
Im not overpowering the sub. Im actually giving it rated OR probably a less.
Old 11-19-2012, 10:18 PM
0/11 sssssss21
Well, in that case, go for it!
Old 11-19-2012, 10:36 PM
I like it a lot. My OCD isn't liking that offset port though, lol.
Old 11-19-2012, 10:43 PM
0/11 ssssss114
I am OCD too, so I understand. The only reason I have the offset port is because my truck is wide between the seats and my 4wd is in the floor, so I have to do the whole console offset to the right because the shifter is on the left.
Made a box in sketchup KTMrida4life Enclosure Discussion & Design Construction Help 25 08-10-2012 10:14 AM
give me your opinions please! tankglh21 General Car Audio Discussion & Questions 8 10-05-2010 02:16 AM
Enclosure ? (playing around on sketchup) crownvic02 Enclosure Discussion & Design Construction Help 5 11-29-2009 01:34 AM
Enclosure Adjustment Opinions aturcotte127317 Enclosure Discussion & Design Construction Help 13 05-06-2009 08:07 AM
Enclosure opinions Pioneer~Saturn Enclosure Discussion & Design Construction Help 61 03-13-2009 10:06 PM
