Port location for rear firing question... - Car Audio Classifieds!
Old 11-20-2012, 08:21 PM
528hz's Avatar
0/11 sssss1792
Default Port location for rear firing question...
So I've got my first SUV and I'm going to be building an upward firing 18" with the port firing toward the rear...
I'm not too sure with my box dimensions that I will be able to put the port right in the middle of the box...will this have any effect on sound/output?
I'm probably going to have to put it on one side or the other, but still firing to the rear none-the-less.
I wouldn't think it make a difference, but I'm need some of you SUV vets inputs...
"When people think you have anger issues, your schedule clears up..."
Old 11-20-2012, 08:50 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Having the woofer on one side (upfiring) and the port backfiring on the other end of the box should be solid.
Louder. Lower.
Team Tupperware
The Following User Says Thank You to Pioneer~Saturn For This Useful Post:
528hz (11-21-2012)
Old 11-20-2012, 09:52 PM
528hz's Avatar
0/11 sssss1792
Why thank you good, friend!
Hope all is well you, and your endeavor!
Old 11-20-2012, 10:23 PM
I agree, especially if the box is pushed over to the left or right corner in the back. Corner loading is tits.
question about L port and center firing port fyerbyrd22 Enclosure Discussion & Design Construction Help 10 10-10-2012 05:51 PM
Port and Sub firing question younggunzbass01 Enclosure Discussion & Design Construction Help 0 02-08-2012 04:49 PM
Suv side firing port question? murderedtahoe General Car Audio Discussion & Questions 7 11-27-2011 04:17 PM
Rear firing vs crx murderedtahoe General Car Audio Discussion & Questions 12 02-22-2010 01:41 AM
Upfiring vs Rear firing NathanLewis General Car Audio Discussion & Questions 16 02-14-2010 01:21 AM
