Subs back to back - Car Audio Classifieds!
Old 11-21-2012, 09:05 AM
0/11 sssssss30
Default Subs back to back
Ok things are coming together and Ill be building a box for my Frontier. The thing is, is that I don't have much room. I want to build a box that will hold two 8's or 10's but the thing is, is that I would need them to be mounted with the but end of the magnets facing each other and because of the small space I would have to have the magnets close to each other. Would that interfere with the sound?
Old 11-21-2012, 09:20 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
You could try Isobaric.
Old 11-22-2012, 01:11 AM
In that image, the last two aren't isobaric. They are just dipoles.
OP: the magnets being near each other shouldn't be a big deal. What's a bigger deal is that you seem to want to fire each sub in an opposite direction. This makes it very difficult to load each driver equally against a reflecting surface, and will run into phasing problems. In general, it's better to have the subs on the same plane or firing at each other.
Old 11-22-2012, 04:54 PM
Wheres The Butta's Avatar
0/11 sssss6101
Feedback Score: 21 reviews
Out of curiosity what is the reason you want to run two instead of one?
The Following User Says Thank You to Wheres The Butta For This Useful Post:
Crunk (11-23-2012)
Old 11-23-2012, 09:17 AM
0/11 sssssss30
OK your right about them pulling. I didn't really put that together but if I was to reverse polarity on one then wouldn't that make them on a push/pull basis.
Ive always had better luck with two over one. I was thinking that with a amp like Saz1500 or BC2000 that maybe I could get a nice 12"d2 and utilizing the air space for one 12 running 1ohm instead, but was afraid that it wouldn't kick as much as two 10's. I suppose now some one's going to school me on this matter.
Thanks for the replies,
Old 11-23-2012, 09:27 AM
Ja Marcus
0/11 sssss6975
You are correct in that they are dipole. However they can also be isobaric driven. Dipole refers to the direction in which the wave travels. But the way in which the drivers are wired (ie push pull) can in fact make them isobaric enclosures.
Old 11-23-2012, 09:30 AM
Benny33's Avatar
Hockey players, man...
0/11 sssss1616
How is that not isobaric? Dipole would be woofers out of phase on opposite faces of the enclosure, right? This looks like a sealed enclosure with two woofers wired out of phase mounted face to face with a sealed chamber between them. Unless I am seeing it wrong...
Sorry to take that into the ditch there.
OP, I don't think you will have any issues with loading/cancellation with what you are proposing. I would be careful not to have the woofers actually touching butt-to-butt in the enclosure though.
Yous just figures that out? All the hots ones is crazy!...And deh ugly ones too. - Toki Wartooth
Old 11-23-2012, 10:13 AM
0/11 sssssss30
I was going to make sure that the butts of the mag. are at least 1" apart. I would put a divider between them but that just takes up more presious air space. Really do you guys think that I should utilize what little bit of space I have for one 12 over 2 8's or 10's. Im completely open to what I do, but I want it to hit. I like loud bass but rather SQ any day. It seems to me that 1500-2000 watts rms should push a SA12 or equivalent pretty good in a 1.0^3 box right. I think the real problem hear is that none of this is exact. 1+1=2, but with stereo stuff like this its all about opinion....unless you have meters hooked up like in competition's. I hate this shit and yet Im soooo addicted to figuring it out!!
Old 11-23-2012, 10:27 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
I'll agree that as pictured they aren't iso loaded. But they are possible alignments of an iso-pair. As pictured, only the first is a isobaric alignment. The other two would need another enclosure of some sort. Otherwise, the middle one is exactly like the OP is talking about or push/pull.
I see no problem with the back to back alignment in the OP other than maybe the pole vents pushing hot air into each other or something. Can you invert one like the one pictured on the far right?
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 11-23-2012, 11:02 AM
0/11 sssss6101
Honestly for simplicity and.cost sake I would say go with a single 12. I can't imagine it would have any less output than the setups you pictured with the 10s
Cyberknife's done, Back at work....Back on Caco Lol Jdubs04ss Off Topic Chat 0 10-26-2011 09:41 AM
rebuilt top end, put distributor back in, suburban wont start. it back fires. kickerfanatic General Automotive Chat 7 09-01-2011 09:21 PM
Subs back, port up bigoooee Enclosure Discussion & Design Construction Help 8 03-31-2011 05:32 PM
New Rebuild: Back at ground zero , but im coming back harder splvictim20 Build Logs 898 10-20-2010 01:20 AM
Sub up, port back.... does the box have to be all the way back to be effective?? NorthBeat General Car Audio Discussion & Questions 5 08-01-2010 08:16 PM
