Sub in Port - Car Audio Classifieds!
Old 11-22-2012, 09:53 AM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
Default Sub in Port
Is it bad if a portion of the sub sits in the port. I built a box for 2 18" hdc3s and the port runs along the bottom of the box. It stops about 6" from the back wall of the box. The subs sit at the back of the box per customer request, and about 3" of the sub sits in the back of the port opening. Is this going to be and issue or will it still work ok?
Old 11-22-2012, 10:09 AM
KickinBlazer's Avatar
0/11 sssss1122
im sure it presents some some kind of acoustical problem
if its to loud your to old!
Old 11-22-2012, 10:11 AM
1loudmonte's Avatar
0/11 sssss2167
Do you think It will hurt the subs, and also this is just a daily driver system, so is this going to cause a noticable lose in output?
Old 11-22-2012, 10:20 AM
0/11 sssss1364
Feedback Score: 25 reviews
im not sure but i think you would have loading issues im sure taylorfade will tell you in a sec as i seen he is on here lol
97 civic ex new build coming soon. head unit poineer premier 80prs fronts/rears diamond audio hex pros mid & high stage amp Diamond Audio HEX 700.4 sub amp diamond audio d6 1500.1 coming sub stage 1 diamond audio d9 15d2 lwire stinger zero gauge & 4 gauge 1 c&d 102ah batts, kenitik 800,200 amp alt mechman
Old 11-22-2012, 10:22 AM
1loudmonte's Avatar
0/11 sssss2167
I hope someone has some good insight on this issue.
Old 11-22-2012, 10:25 AM
0/11 ssssss577
it think that may cause some coil rock
Cartunz 3X show 6-24-2012 $500 for loudest non Port or Super Port score bdufner Competition Corner 2 06-16-2012 07:29 AM
