2 SDC2.5 15's - Car Audio Classifieds!
Old 11-23-2012, 06:43 PM
CEGrizzly's Avatar
0/11 ssssss268
Default 2 SDC2.5 15's
So, I just ordered 2 AQ SDC2.5 15's, and an AQ1200 to power them, and my dilemma now is, I don't know what type of box, and how big I need it.. So looking for some help here, so I can have someone design it for me and I can build it!
Specs per sub here:
Model
SDC2.515 Woofer Size
15"
Fs
33 Hz
Qts
0.643
Qes
0.705
Qms
7.405
Vas
44.340
Le mH
3.05
Sensitivity 1W/1m
85.69 dB
Magnet Weight
140 oz
Coil Diameter
2.5"
Useable Throw
2.3"
RMS Power
600
Peak Power
1200
Mounting Depth
7.5"
Circle Cutout
14"
Model
SDC2.515
I should have plenty of room for them. I drive a jeep.
Just don't know if I should do ported.. or what..
Old 11-23-2012, 07:34 PM
kremer90's Avatar
0/11 ssssss284
I just ordered one to finish my wall too
I've messed with the sd line a lot. They do like bigger boxes. And a tune from 34-37. Anything lower they start sounding sloppy. Unless you keep the port area down. That's just my personal experience though.
Learning to get "loud"
Old 11-23-2012, 07:54 PM
CEGrizzly's Avatar
0/11 ssssss268
Thanks for the imput! But I don't know anything about boxes! Is it possible to have someone design one for me just off the specs i provided??
Old 11-23-2012, 07:56 PM
badmofo529's Avatar
0/11 sssss3329
get it around 7.8-8.3 ft^3, with around 120-130 in^2 of port tuned to 36ish. it shall wang. thats close to the specs of my last box and i was doing 144's sealed on the dash, and 148's in the kick. it got pretty damn low too.
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 11-23-2012, 08:01 PM
CEGrizzly's Avatar
0/11 ssssss268
What were the dimensions? And would that still work if I had them firing up and the port firing up? Don't want them firing towards the hatch in my jeep.
Hopefully there's enough room or I just screwed myself!
Old 11-23-2012, 08:10 PM
kremer90's Avatar
0/11 ssssss284
I can get you a design up for free if ya want. Just pm me.
Old 11-23-2012, 08:14 PM
badmofo529's Avatar
0/11 sssss3329
they were for my s10, so the dims would most likely be of no use to you.
'97 chevy s10
-kenwood x994
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 11-23-2012, 08:20 PM
CEGrizzly's Avatar
0/11 ssssss268
Damn.. I'm worried I won't have enough room now..
Old 11-23-2012, 09:03 PM
kremer90's Avatar
0/11 ssssss284
Oh you should have plenty room. 8 cubic ft isn't a whole lot in a SUV lol. Of course it would be closer to 9.5 ish gross vol.
Old 11-23-2012, 10:57 PM
0/11 sssss2649
I'm sure you'll be fine. Just make the box as big as you can and you can switch to aero ports to save space (single 8" or 2 6"). If the box is a bit smaller that's fine too. The smaller the box, the more power the subs can handle and the less efficient the box is. Personally I would upgrade to an AQ2200 or strap another aq1200 to get the most out of your sub.
2 sdc2.5 15's and a aq 1200 badmofo529 General Car Audio Discussion & Questions 14 06-06-2011 01:48 AM
aq sdc2.5 15's blkmrideon22s General Car Audio Discussion & Questions 10 03-17-2011 09:31 AM
WTB: two AQ sdc2.5 15's Silenkiller Wanting to Buy (WTB) 1 03-12-2011 12:24 PM
4 sdc2.5 15's hdman87 General Car Audio Discussion & Questions 21 10-18-2010 03:57 PM
(4) sdc2.5 15's vs. (2) mtx 9500 15's? Dbmonster General Car Audio Discussion & Questions 9 08-12-2010 12:11 AM
