Port Bends? - Car Audio Classifieds!
Old 11-25-2012, 01:06 PM
Hdorre's Avatar
0/11 ssssss540
Default Port Bends?
How many bends are too many?
Im designing a box for a pair of SA8v2s on a RF 1500bdCP. In order to get enough port area with low enough tuning, I havent found a way against using 3 port bends.
Also, in this design there are ~4.625" between the port opening and the back of the sub. Will I have to worry about unloading? The port is 2.5" wide (if that matters).
Old 11-25-2012, 01:17 PM
you will be fine.
Old 11-25-2012, 01:19 PM
0/11 sssss3986
no such thing
Old 11-25-2012, 01:22 PM
if these designs can use this many bends and work as well as they do your 3 bends will not effect anything.
Old 11-25-2012, 01:35 PM
Hdorre's Avatar
0/11 ssssss540
Sweet.. Thats what I wanted to hear. Thanks!
I have one more question. How much space should be behind the back of a speaker and the port? In the design above, the port is 2.5" wide and theres just over 4.5" between the port and back of the sub.
Old 11-25-2012, 01:41 PM
Mr.G6's Avatar
0/11 sssss4614
it doesnt matter
if the sub has no pole vent it can basically touch the port wall if need be
if the sub has a pole vent u need to stay the same distance away from the wall as the opening is.. so if u got a 1" round vent onthe motor stay away from that nearest wall at least 1 to 2"
in your case you have 0 issues
2000 Gmc Sonoma ext cab
Old 11-25-2012, 02:02 PM
goatskindreams's Avatar
Do you even demo?
0/11 sssss1797
whats up with the pocket behind the port?
Team AST-2 15" Everest Sound Labs Bdx.Powered by Flatline audio ba2
Team Psychoacoustics-11" Adjustable Psycho Port. 12 T3 Audio 6x9s for mids
Old 11-25-2012, 02:15 PM
Hdorre's Avatar
0/11 ssssss540
Originally Posted by Mr.G6 View Post
it doesnt matter
Awesome! Thank you.
Im not sure what youre talking about. Maybe the angle made an illusion. I attached a pic that has different colors. Maybe you can use it to elaborate.
Old 11-25-2012, 02:18 PM
Do you even demo?
0/11 sssss1797
Awesome! Thank you.
between the purple and blue boards
Old 11-25-2012, 02:27 PM
Hdorre's Avatar
0/11 ssssss540
My ports "created" that pocket. Should I just block it off? There are only four hundredths of cubic foot in that space.
Cartunz 3X show 6-24-2012 $500 for loudest non Port or Super Port score bdufner Competition Corner 2 06-16-2012 07:29 AM
Can you do 90degree bends in an aero and still get good results? 1ndatrunk Enclosure Discussion & Design Construction Help 6 07-16-2011 08:51 PM
