Enclosure Opinions - Car Audio Classifieds!
Old 11-25-2012, 05:59 PM
Hdorre's Avatar
0/11 ssssss540
Default Enclosure Opinions
So, I spent a few hrs messing with designs for a pair of SA8v2s on a RF T1500bdCP.. and this is probably the one Im gonna use. I was going to use a center port because its different... but traditional "L" ports are MUCH easier lol
Im planning on blocking off the "cubby" between the aqua and green. Theres only .049 of a cube in there. My calculated net volume and tuning are with the cubby blocked off.
The lines between the sub cutouts represent sub depth.
Box Specs
Port Area: 16.88 sqin
Gross Volume: 1.687 ft^3
- 0.16 ft^3 (sub displacement)
- 0.049 ft^3 (block off cubby)
Net volume: 1.13 ft^3
Fb: 34.16Hz
Port Specs
Height: 7.5
Width: 2.25
Length: 30
Cutout Sheet
(1) Red: 19.75 x 7.5
(2) Orange: 6.25 x 7.5
(2) Yellow: Look at Paper 9 Depth
(1) Dark Green: 8.75 x 7.5
(1) Light Green: 2.25 x 7.5
(1) Aqua: 7.5 x 7.5
(1) Blue: 7.75 x 7.5
(1) Pink: 37 x 7.5
(2) Light Brown: 8.25 x 7.5
(2) Dark Brown: 6 x 7.5
Port Dimensions (Down Middle)
First: 7.375
Second: 6.75
Third: 5.25
Fourth: 10.625
7.375 + 6.75 + 5.25 + 10.625 =30
Soo... yay or nay? Does anyone have any tips, or does this design look solid?
Opinions of this enclosure 1loudmonte Enclosure Discussion & Design Construction Help 3 11-22-2012 10:49 AM
Made Enclosure in Sketchup, Give me Opinions! screwgreen Enclosure Discussion & Design Construction Help 5 11-19-2012 10:43 PM
Opinions wanted on enclosure Thixx Enclosure Discussion & Design Construction Help 7 08-22-2010 04:05 AM
Enclosure Adjustment Opinions aturcotte127317 Enclosure Discussion & Design Construction Help 13 05-06-2009 08:07 AM
Enclosure opinions Pioneer~Saturn Enclosure Discussion & Design Construction Help 61 03-13-2009 10:06 PM
