Box Help with HDC3 12's - Car Audio Classifieds!
Old 11-26-2012, 10:15 AM
0/11 ssssss461
Default Box Help with HDC3 12's
I took advantage of the black friday sale! Now it's time to plan. Anyone have experience with the new copper HDC3 12's? They'll be going in a Ford Edge. I'm thinking 5 cubes @ 35hz with 80 in^2 of port. Both subs and port facing rear. I've also thought about port facing drivers/passenger side. Anyone have any suggestions? Looking for input from people that have experience with this sub in this type of vehicle; on anything from enclosure size to tuning to port area to sub/port orientation.
Thanks!
Old 11-26-2012, 10:35 AM
davecubs14's Avatar
0/11 sssss1845
What kind of power do you have? I have quite a few AQ subs, lol. That box should work just fine. If you need to take it down to 4.5 cubes, it'll still be fine. That's what I have for a couple 12s. But around 110 sq in of port. It's more for spl though. So 80 sq inches of port should be fine for daily. I would do sub up, port back. If you don't have any room between the box and back hatch, do port to the side.
2001 2 Door Blazer -
'11, '12, '13, '14 Meca Street 2 AL State Champ
AL Meca Street 2 Record Holder(151.6)
2012 Meca World Finals - Street 2 - 3rd Place(148.7)
2013 Meca World Finals - Street 2 - 2nd Place(151.1)
2014 Meca World Finals - Street 2 - 2nd Place(152.3)
The Following User Says Thank You to davecubs14 For This Useful Post:
brandon_s0854 (11-26-2012)
Old 11-26-2012, 10:45 AM
0/11 ssssss461
Right now, just an AQ2200. Have plans for a second one in the future. This is definitely for daily. Don't want to be too peaky around tuning, and don't want to lose too much output below tuning. That's why I chose 80 in^2 of port. Sounds like I'm in the right ballpark for what I'm looking for. I'm not really convinced on subs facing up though. I've played around with that before and found the upper bass to be better when they're facing the rear.
Old 11-26-2012, 11:04 AM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
i designed a box for these same subs on the same amp for a nissan versa hatch. box was [email protected] subs up port up, it was pretty damn loud.
The Following User Says Thank You to Ryan1126 For This Useful Post:
Old 11-26-2012, 11:11 AM
0/11 ssssss461
Thanks! You remember how much port? I'm not looking for just loud. I'm expecting it to be loud. lol. Just trying to avoid extremely peaky response and keep the lows.
Old 11-26-2012, 11:17 AM
davecubs14's Avatar
0/11 sssss1845
Sorry, just saw hatch and I think sub up, lol. I have a blazer so i've never worked with that shape vehicle before. Either way, they should punish the lows. My box is "tuned" to 52 on torres but the few members on here who heard it can vouche that it sounded great and dug down to 35 with authority. And that's low enough for me, lol. Good luck man!
Old 11-26-2012, 11:39 AM
0/11 ssssss461
I'm actually wondering if 35 is too low of a tuning, but not sure. When I had my hdc3 10's, they were in 3cf @ 35hz and absolutely destroyed from 25-45hz. I actually had to turn my ssf up to balance out the frequency response. lol. I'm hoping these will be a little flatter.
Old 11-26-2012, 12:49 PM
Mr.G6's Avatar
0/11 sssss4614
i built a box for a new style hdc3 12.. customer wanted it EXACTLY to aq's specs//
so i tuned it to 38hz used 14.5" of port per cube and 2.5ish cubes net..and literally anything below 34 35hz was basically air movement.. i was VERY dissapointed,. so i actually made another box free of charge..and did 30hz tune 14" per and 2.5 cube.. NOW it played welll below 30hz and topped out in the mid 40hz range like around 45 46hz..
also..i would do sub up port back OR subs back and port to the passenger side
2000 Gmc Sonoma ext cab
The Following User Says Thank You to Mr.G6 For This Useful Post:
Old 11-26-2012, 12:51 PM
Mr.G6's Avatar
0/11 sssss4614
wow... 35hz aint even near being low lol..
Old 11-26-2012, 12:55 PM
whos that's Avatar
0/11 sssss1635
Hm, i had a 15 in a 4.5 cube box @ 38, it didn't necessarily "destroy" the lows, but it sounded awesome at 30hz and below, and it never bottomed out either.
Building a box for 2 hdc3 12's Abcdefranklin General Car Audio Discussion & Questions 5 02-03-2012 11:55 PM
AQ HDC3 12's munches4bass General Car Audio Discussion & Questions 2 10-30-2010 04:12 PM
new box for 2 hdc3 12's? 98Expo Enclosure Discussion & Design Construction Help 6 08-27-2010 03:30 AM
2 hdc3 12's box help dylan9999 General Car Audio Discussion & Questions 9 08-11-2010 11:59 PM
