process of painting an enclosure - Car Audio Classifieds!
Old 11-29-2012, 09:36 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Default process of painting an enclosure
alright a lot of people have asked how to paint their enclosures (color match) i also would like the know the process, i have seen some amazing painted enclosures and it is possible i may do it for my upcoming build.
I'm looking for a step-by-step process broken down, what kind of gun you use, what kind of paint, how many coats, what grit sand papers are needed etc.. anybody willing to make a tutorial we can sticky or can walk me through the process and i will take pictures and video of a how to and write up a nice tutorial to sticky.
Old 11-29-2012, 09:49 PM
99Bonney's Avatar
0/11 sssss6246
X2
I'm interested.
Old 11-29-2012, 10:07 PM
0/11 sssss2011
Feedback Score: 61 reviews
what I've done for a small area like port or one wall.
1. spray with a sand able high build primer (duplicolor is what I've used)
2. lightly sand with 100 grit sand paper
3. spray another coat
4. lightly sand with 400 grit sand paper
5. sand with 800 grit
6. apply first coat of paint or base (i have the cheap Harbor Freight HVLP with factory tip, paint I use is the Duplicolor Paint shop)
7. apply color coat or second coat of paint
8. apply clear coat
this is what I do and it works well for me. there are other ways that i'm sure others will chime in with but it works for me. now if i'm painting fiberglass box or large area's I don't so this, i change up some things.
Old 11-29-2012, 10:11 PM
Ryan1126's Avatar
0/11 sssss9178
8. apply clear coat
okay will im looking for a tutorial to paint bare MDF, so that's that i wanted to see ^ how does the harbor freight gun hold up?
Old 11-29-2012, 10:26 PM
0/11 sssss1480
Feedback Score: 63 reviews
8. apply clear coat
Sounds almost on par with what I do. Everyone does it a little different. You just gotta find what works best for you
I always add a sealer as well after the high build primer
I also sometimes wet sand, starting with 800-1200 grit going up to 3000 grit sometimes then buff it until I'm sick of it.
Old 11-29-2012, 10:28 PM
Ryan1126's Avatar
0/11 sssss9178
how much does it usually cost in paint?
Old 11-29-2012, 10:30 PM
MopaRBumpiN's Avatar
0/11 sssss3819
Feedback Score: 35 reviews
This is a very dumb, newbish question but how do you wet sand?
Team DefJ, Team XS Power, Team Audio Technix
Headunit: Pioneer DEH-80PRS
Tweeters: Vifa XT25
Midbass: Silver Flute 8"
Highs Amps: Soundstream TN4.900
Sub: Cascade Design Omega 15"
Sub Amp: Incriminator Audio 20.1
Electrical: XS Power D2400, XS Power D3100
Deadener: Alpha Damp and Audio Technix 80 mil
Old 11-29-2012, 10:35 PM
ridintwo6s's Avatar
0/11 sssss1791
Got to use a SEALER
Old 11-29-2012, 10:37 PM
0/11 sssss1480
I just have a bowl of water next to me and keep whatever your sanding wet as well as the sandpaper. I will dip the paper keeping it wet and free of any debris on it.
Old 11-29-2012, 10:44 PM
0/11 sssss1480
I use all napa brand stuff
1 quart of high build primer-$32
1 quart of sealer- $25~
1 pint of base paint- $15-25 depending on color
1 quart of clear-$30
1 quart of reducer- $12 if your painting now get fast reducer
Depending on paint and clear you might need hardener
Also cups, filters, and stirrers but they usually throw that in for free
You will also have leftovers on all that stuff so really one job doesnt cost that much
WHAT is the process to install a coil, spiders, and cone. XORstatus General Car Audio Discussion & Questions 12 03-14-2012 09:24 PM
new police force and election process korey_hofer Announcements - Suggestions - Feedback - Support 56 05-13-2009 03:34 PM
[COMPLEX] The Process of Powder Coating an Amp danteBirosel Tutorials & Quick References 1 11-12-2008 02:36 PM
