Wood Cutting For Dummies - Car Audio Classifieds!
Old 12-02-2012, 12:41 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Default Wood Cutting For Dummies
okay so i see a lot of people asking how to get straight cuts without a table saw. Not all of us have access to or room for a giant table saw. Also a good sized table saw will run you $3k+ and those little portable table saws are a pain to rip a 4'X8' piece of MDF on, even if you build a table around it. So i will show you guys how I do it, this is not the only way to do it, everyone does it different, but my way seems to work great, i always have straight cuts and have never been off more than a 1/32", and thats just because i was moving fast, this process does take time, so you need patience but its all worth it in the end.
First off, get one of these from Home Depot, they are only $20
No Home Depot close to you?
http://www.fleetfarm.com/mff/detail/...FUdxQgodnTgAag
Be careful with them as they are easy to bend, also the black extension piece is easy to bend / break. Also if you are ripping a sheet long wise and you have to use the extension, be sure to drive a screw, or nail (i use a thumb tac) against the backside of the guide in the middle of it because when you run your saw along it, it will bow in the middle and your cut will vary about 1/8" in the middle.
Next you need to figure out the measurement of the table on your saw. (while looking down at your saw when holding it) you need to figure out the measurement from the left side of the blade to the right side of the saw (the side that butts up against the saw guide) my skilsaw is 3-11/16" from the left side of the blade to the right side of the table. Now sometimes you have a piece of wood that isnt long enough to get that extra 3-11/16" off of you you then have to do the cut backwards, in this case you will be cutting from the other direction, so you then need to account for blade width or else you will end up a 1/16" short on your cut (i use diablo blades they are 1/16" width) so you will actually set the guide 3-10/16" over from your cut.
Its pretty easy once you figure out the measurement of your saw table, for example if i have to make a 12" cut, i set the saw guide at 15-11/16" and then after the cut im left with a 12" piece, here is a picture to show you after the cut.
Believe me, even after all the boxes i have built i still trip myself up sometimes, but i always measure twice, and cut once. An easy way to figure out the table width on your saw is to set the guide on a piece of wood and just rip along it, then measure from the guide over and then add the blade width ontop of that.
Reminder: always make sure your sheet is square before cutting, sometimes sheets are not squared, in which case you have to do it! Also if you use a left handed saw, take that into account.
On the dot.
The Following User Says Thank You to Ryan1126 For This Useful Post:
tylork92 (12-02-2012)
Old 12-02-2012, 03:39 PM
0/11 sssss3842
great write up.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 12-02-2012, 03:51 PM
Ryan1126's Avatar
0/11 sssss9178
hopefully someone can find this useful i know it would have made life a lot easier on me, home depot messed my cuts up enough times.
Old 12-02-2012, 03:55 PM
Silver-N-black's Avatar
0/11 sssss3544
I'll use it next time I build something
Old 12-02-2012, 07:39 PM
davidrforbus's Avatar
0/11 sssss6030
Gonna get one for christmas. How do you square up your sheets of wood?
Old 12-03-2012, 08:42 PM
0/11 ssssss106
I have one of those and that's the same way I do it, it works great.
Old 12-03-2012, 08:49 PM
MopaRBumpiN's Avatar
0/11 sssss3819
Feedback Score: 35 reviews
I only have Lowes near me. Do you know if Lowes has an equivalent?
Team DefJ, Team XS Power, Team Audio Technix
Headunit: Pioneer DEH-80PRS
Tweeters: Vifa XT25
Midbass: Silver Flute 8"
Highs Amps: Soundstream TN4.900
Sub: Cascade Design Omega 15"
Sub Amp: Incriminator Audio 20.1
Electrical: XS Power D2400, XS Power D3100
Deadener: Alpha Damp and Audio Technix 80 mil
Old 12-03-2012, 08:55 PM
0/11 sssss1286
Another easy way to do it is to make ur own T square / Guide ...
once u make ur first cut it will cut the excess of the bottom board off and u can use that to help line up ur cuts with just a simple mark of a pencil and it will be perfect everytime
0/11 ssssss281
looks like im bringing my wood to you next time i need straight cuts since someone decided they needed my table saw more then i did....
Old 12-03-2012, 10:49 PM
0/11 ssssss320
Good.write.up but.how do.you make.sire.you get square cuts do.you just use the t square draw a line at the edge and.cut.excess off ?
Electrical for Dummies: Big 3, alts, batteries, etc... beckerson1 Tutorials & Quick References 15 03-01-2013 06:33 PM
Cutting out maverickdog8 General Car Audio Discussion & Questions 7 06-07-2012 02:27 PM
Craigslist dummies clickclakblastem52 General Car Audio Discussion & Questions 4 02-09-2012 11:04 AM
Which wood to use? jbizzle Enclosure Discussion & Design Construction Help 14 11-28-2009 11:12 PM
wood???? andrew198501 Enclosure Discussion & Design Construction Help 33 09-26-2008 09:41 AM
