HDC3 10x2 - Car Audio Classifieds!
Old 12-02-2012, 05:26 PM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
Default HDC3 10x2
I was wondering if 4 cubes gross is enough for a pair of HDC3 10s on a AQ 2200d? If so how low can you tune these and still get good results. It is going to be a daily driver install.
Old 12-02-2012, 05:39 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
the long port from tuning low will eat up alot of your net space
Old 12-02-2012, 05:45 PM
1loudmonte's Avatar
0/11 sssss2167
So what would be the lowest I could tune and still stay in the required net airspace. I know AQ says no less than 2.5 net for a pair?
Old 12-02-2012, 06:03 PM
sthrnbumpn's Avatar
0/11 sssss2961
well i was hoping my post would spark someone else to give a better response....
really, im not sure what hdc's like, as afar as tuning/net goes
usually times like this, i do it with a calculator and pen and paper, i do know that fs will give you a good idea of what your tuning should be
Old 12-02-2012, 06:10 PM
1loudmonte's Avatar
0/11 sssss2167
The FS on the 10 is 41 hz. Im working on a sub forward port forward enclosure. The dimensions I have to work with is 39.25 wide x 12.75 height x 18 deep. This is in a 06 chrysler 300 and lets me still open the door to the spare tire well.
0/11 ssssss461
I had the old style hdc3 10's. And I can tell you that you don't want to put them in less than 3cf. Tune between 36-38hz and you'll be happy. You don't have to have a ton of port. 40 in^2 port 18" long would get you where you want to be tuning wise and should still live enough room for 3cf gross volume. Don't do less than 40 in^2 though. That would be the minimum I'd recommend.
Old 12-02-2012, 06:17 PM
0/11 ssssss461
I've attached a quick box put together on RE Audio's site. There's 45 in^2 of port and should end up around 36-37hz.
Old 12-02-2012, 06:19 PM
sthrnbumpn's Avatar
0/11 sssss2961
39.25 wide x 12.75 height x 18 deep. this would give you 5.21 cubes
the port that brandon mentioned is .5 cubes, your sub is around .2 at the most
Old 12-02-2012, 06:20 PM
0/11 ssssss461
Exactly. There's enough room. Not much to spare, but there's room.
Old 12-02-2012, 06:21 PM
1loudmonte's Avatar
0/11 sssss2167
Thanks man I appreciate that.
FS: 10" aq hdc3 and hdc3 motor Bushj311 10" Subwoofers 14 05-08-2011 03:12 PM
Need an AQ HDC3 motor (or blown hdc3) Bsktbll895 Wanting to Buy (WTB) 0 06-16-2010 07:39 PM
Blown hdc3/ hdc3 motor basshead08 Wanting to Buy (WTB) 5 03-05-2010 04:55 PM
hdc3-a 18 or hdc3 18s blkmrideon22s General Car Audio Discussion & Questions 20 01-16-2010 10:20 PM
box sizes for HDC3-HDC3-A Fosgate1 General Car Audio Discussion & Questions 1 10-01-2009 10:26 AM
