Sub / port orientation? My first trunk car - Car Audio Classifieds!
Old 12-02-2012, 11:44 PM
0/11 ssssss664
Default Sub / port orientation? My first trunk car
So i'm underway purchasing and planning for my new build. Front stage aside, the sub stage is going to be 4 RE audio REX8 sub woofers. The box is going to be ~ 5.8 cubic feet after displacement, tuned to 38hz with 2 4" aero ports.
My question is, how should I orient the subs and port for maximum effect? or does it matter? I've never built anything for a car with a trunk, only suv's in the past.
Ive been reading into it a bit, and it sounds like the combination of subs up, port into driver side trunk panel is recommended the most?
Car is a 2010 Volkswagen jetta
New Jeep. 142db as of now, Details to follow.
Old 12-03-2012, 07:41 AM
whitetrash84's Avatar
0/11 ssssss125
You're going to put four 8" subs in 5.8 cubes?
Old 12-03-2012, 07:43 AM
MopaRBumpiN's Avatar
0/11 sssss3819
Feedback Score: 35 reviews
Puzzled me too....
OP, are you wanting to conserve on space or don't care and just want maximum output?
Team DefJ, Team XS Power, Team Audio Technix
Headunit: Pioneer DEH-80PRS
Tweeters: Vifa XT25
Midbass: Silver Flute 8"
Highs Amps: Soundstream TN4.900
Sub: Cascade Design Omega 15"
Sub Amp: Incriminator Audio 20.1
Electrical: XS Power D2400, XS Power D3100
Deadener: Alpha Damp and Audio Technix 80 mil
Old 12-03-2012, 10:34 AM
0/11 ssssss664
Originally Posted by MopaRBumpiN View Post
Puzzled me too....
5.8 cubes is right above the "standard" for what RE calls for. 5.6 is what they say. Seems huge to me, too. But maximum output is the main concern, weight of enclosure second.
Old 12-03-2012, 11:17 PM
0/11 ssssss664
I guess on this entire forum of SPL freaks nobody has any idea as to what is the best sub / port arrangement.
Old 12-03-2012, 11:42 PM
TheJesus's Avatar
Yawning
0/11 sssss1921
Nope. Most test each orientation to see which works. But typically subs up or forward, port on driver side into the cabin is loudest to meter.
I used to have that walled Challenger, then it got totaled...
2015 IASCA Welterweight Champion and Record Holder - 156.0 Avg (No door blockers)
2016 IASCA Welterweight Record Holder - 157.7 Avg (Door blockers used)
Team Sundown Audio & Fullriver Faction Member
Old 12-04-2012, 01:01 AM
0/11 ssssss125
I still don't see how you are going to run 1.4 cubes per 8" sub. Hope you aren't planning on running too many watts.
Sub back port to driver side was good in my trunk until I did subs/port forward and sealed off.
Old 12-04-2012, 01:43 AM
Ricksi30's Avatar
0/11 ssssss997
Lol that volume is WAY off. And why the hell would you not use larger drivers if you are willing to give up that much space? Sorry for being blunt, but really?
Head unit: Kenwood Excelon KDC-X996
Front stage: Alpine Type X mids Vifa Neo 1" silk tweeters
Component amp: PPI Bk800.4
Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
Sub amp: PPI Bk1300.1
Team SSA
Old 12-04-2012, 10:19 AM
0/11 ssssss664
Well the volume for the enclosure came right off RE's website. I figure they know, considering they made the woofers. Im thinking I'll try subs up, port into drivers side.
Old 12-04-2012, 10:24 AM
0/11 ssssss664
Because I'm only going to run one battery, and have about 600 watts rms to play with. Into only a 4 ohm load. (using a d7152 bridged). So multiple drivers makes the most sense. My driver choice only needed to handle 200 or so watts and weight is the second biggest concern. ~ 30 lbs for the drivers and probably the same or a bit more for the enclosure. Cost is another concern, I paid like 160 bucks for the 8's and Im pretty happy with the choice.
Like everything, there are multiple ways to get the same results. Always wanted to do a bushel of 8's.
And again, the volume requirements for the enclosure came right of RE's website. I've heard the same subs in similar volume(s) and power. They worked well.
Quasi 6th Order Bandpass port orientation... quagmire Enclosure Discussion & Design Construction Help 10 06-07-2012 10:23 PM
Port & Sub Orientation in a Corvette 528hz General Car Audio Discussion & Questions 0 03-22-2012 03:01 PM
What woofer/port orientation would you choose? (Trunk) Ronmeister Enclosure Discussion & Design Construction Help 19 11-17-2011 01:56 PM
Port and Sub Direction in Trunk Car jd93kid General Car Audio Discussion & Questions 28 11-29-2010 09:18 PM
subs up/port back in a trunk car? Fatboy501 General Car Audio Discussion & Questions 71 06-15-2010 04:42 PM
