Check my 4th order specs? - Car Audio Classifieds!
Old 12-09-2012, 01:09 PM
0/11 ssssss664
Default Check my 4th order specs?
REXS4 8's subs.
Figures are per pair of subs.
.97 sealed - 2.76 ported
48hz tuning - 4" x 2.399" port dimensions - 29.376 cubic inches of port volume.
Port seems awfully small to me. Would someone please check my numbers?
New Jeep. 142db as of now, Details to follow.
Old 12-09-2012, 01:32 PM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
got a link to the T/S parameters?
2000 2dr Blazer
Old 12-09-2012, 02:07 PM
0/11 ssssss664
http://reaudio.com/documents/rex_single_manual[2012].pdf
Old 12-09-2012, 04:36 PM
0/11 sssss5201
page not found
2000 2dr Blazer
Old 12-09-2012, 04:47 PM
0/11 sssss5201
that sealed resonance is 40hz i believe
2000 2dr Blazer
Old 12-09-2012, 06:58 PM
0/11 ssssss664
So tune the ported chamber to 40hz as well? Forgive me, this will be my first 4th order.
Old 12-09-2012, 07:05 PM
0/11 sssss5201
you would, but thats way to low, get your resonance up, to about 47
2000 2dr Blazer
Old 12-09-2012, 07:10 PM
0/11 sssss5201
.75 per pair=44hz
.5 per pair= 51 hz
2000 2dr Blazer
Old 12-09-2012, 07:38 PM
0/11 ssssss664
.75 per pair=44hz
.5 per pair= 51 hz
So reduced sealed volume to ~.65 per pair and tune port to 47? How would I determine the resonance of a particular sealed volume? So I can match the port and sealed volume.
Old 12-09-2012, 07:49 PM
0/11 sssss5201
where did you read you had to match port and sealed volume? i read you need half of cone area in port area.
say 100sq in of cone area, you start with 50 sq in of port area
determine sealed resonance with a program. winiSD
2000 2dr Blazer
Check my 4th order figures. nicyousuckk Enclosure Discussion & Design Construction Help 0 12-07-2012 11:03 PM
Check my Port specs before i build? Kidthump Enclosure Discussion & Design Construction Help 20 10-09-2011 01:51 PM
one last check on 4th order tymoto21 Enclosure Discussion & Design Construction Help 29 07-10-2011 07:55 PM
double check my 4th order? twisted Enclosure Discussion & Design Construction Help 22 01-22-2010 05:40 PM
