6th order in 4 door Tahoe. Help. - Car Audio Classifieds!
Old 12-10-2012, 02:26 AM
Amp blower!
0/11 ssssss483
Default 6th order in 4 door Tahoe. Help.
So I jus picked this up. Need help on wall. I don't know a lot about 6th orders. So I need help. So I want to do is use 4 dc lvl6 m1 18's. I do want space in the back for batts and amps. As of now I don't know how much power I'm going to be using and how many batts I goin to use. How much space do I need for the 4 18's in a 6th order?
Edit: I jus want to do something different then a flat wall. Last thing I want to do is a flat wall.
Thanks for the help
Old 12-10-2012, 02:36 AM
dphat's Avatar
CACO Late Night Crew
0/11 sssss3366
How much power u using?
Sent from my Venture using Tapatalk 2
Team Unlimited Excursion
Team SoundQuest
Old 12-10-2012, 08:56 AM
Amp blower!
0/11 ssssss483
I don't know how much power yet.
Old 12-10-2012, 09:01 AM
0/11 ssssss518
i say 50 cu ft net for a properly built sixth
Old 12-10-2012, 09:10 AM
Amp blower!
0/11 ssssss483
I should have enough. Should I go bigger? What are the ratio's? What's a good ratio for daily? I love the lows, so I would love to tune below 40hz.
Old 12-10-2012, 09:25 AM
0/11 ssssss518
If you are going to do a sixth the bigger the better...
I think a 2:1 or bigger would be a good start
And as far as tuning goes you could do ~53hz for the front and ~28hz for the rear like Paco, and his is set up to kill the lowzzzzz
Really just tune the rear and shrink the port of the front port till it stops gaining
Old 12-10-2012, 09:34 AM
murderedtahoe's Avatar
Mr. Low End Monster
0/11 sssss3512
Love the look, i may have to copy your front end lol
Amp blower!
0/11 ssssss483
Where did Paco peak at? And who does the first tuning reflect on the second? Does the second tuning( saying I do tune at 53)raise the overall tuning?
Old 12-10-2012, 09:35 AM
0/11 ssssss464
yea with using lvl6's that enclosure will be HUGE for a 6th to be efficient
Amp blower!
0/11 ssssss483
Go head. I don't have a copyright on it! Lol
2 door tahoe on CL! 03navi Bargain Bin 1 05-21-2012 08:50 PM
